How did you find out it was in unscheduled compatibility? I am concerned since mine hasn't been scheduled yetfinally, after several calls and emails I got my mach e out of the stuck "unscheduled compatibility" had to talk with the manager since my salesman kept coming back with "there's nothing they can change" it was the parking assist prep kit, knocked 200+ off the price and it's now in unscheduled-clean. Hoping for a production date soon.
Your dealer should be able to tell you. You can also contact ford, easiest is through chat https://www.ford.com/help/contact/?gnav=header-support#chatHow did you find out it was in unscheduled compatibility? I am concerned since mine hasn't been scheduled yet
Ford website indicates the dealer can make changes to orders after placed on website, https://www.ford.com/buy-site-wide-...your vehicle, you,further changes can be made. If dealer is playing dumb, I recommend go down to the dealer and insist somebody help ensure the park assist is changed to a prep kit (-$325), and print out a revised order sheet for you. While there, make sure the priority code is a 10. They can change that too.How did you find out it was in unscheduled compatibility? I am concerned since mine hasn't been scheduled yet
What does the priority code mean?Ford website indicates the dealer can make changes to orders after placed on website, https://www.ford.com/buy-site-wide-...your vehicle, you,further changes can be made. If dealer is playing dumb, I recommend go down to the dealer and insist somebody help ensure the park assist is changed to a prep kit (-$325), and print out a revised order sheet for you. While there, make sure the priority code is a 10. They can change that too.
One other question, I assume if my order is unscheduled clean it means the park assist prep kit was already taken care of I assume?When I went in to change the park assist to a prep kit, I asked about changing the CR1 to a premium and was told I couldn't change the model. Dealer indicated all I could do was change exterior color or add AWD. If I wanted a premium, it would be a new order. Priority code is a way for the dealer to tell Ford which cars it has ordered have highest priority. They can set it between 10 and 19, 10 being highest priority and 19 being lowest. If it's a small dealer with few orders, this may not mean much. When I accepted changing park assist prep kit, I requested the priority code be changed to 10, based on what I read in this forum. It was 19 on original order. Don't know if it made a difference, but I felt better.
I would ask the dealer. The dealer indicated Ford notified them about the park assist.One other question, I assume if my order is unscheduled clean it means the park assist prep kit was already taken care of I assume?
I would assume so... otherwise you would have a compatibility issue. Mine didn't change to unscheduled-clean until after I was changed to the prep kit. If you look at your order online at the Ford website under additional features it should now say Active Park Assist Prep Kit if the change was made (as least mind did).One other question, I assume if my order is unscheduled clean it means the park assist prep kit was already taken care of I assume?
