- Jun 24, 2020
- Vermont
- 2021 MME Premium AWD SR Infinite Blue
Well played.Are you trying to trigger @generaltso or what…
Well played indeed! I wont kill a newbie poster, but should see the search bar and try that first. But, figured havent seen many lately so getting betterWell played.
You have to make sure it sits in the well and havent had problem. I did at first but just played with it and all good.Is anyone else having an issue with the privacy screen on the trunk, i put mine back, but it falls off every drive. I tried searching on mache forums, but no one seems to have that issue.
i've tried, i promise; tweaked it mid-trips, etc. its just always seems to come out.You have to make sure it sits in the well and havent had problem. I did at first but just played with it and all good.
Read a thread that said to get small rubber rings and place them around to hold it in place if that helps?i've tried, i promise; tweaked it mid-trips, etc. its just always seems to come out.
Just wanted to check and see if Ford made it right and delivered your car. I am hoping everything was finally straightened out and you have your mach e now.Thank you.
I have whined (vented) about it all too much on this forum. I will post back when and if anything changes.
Thank you for asking but I have have not heard anything from Ford or dealer.Just wanted to check and see if Ford made it right and delivered your car. I am hoping everything was finally straightened out and you have your mach e now.
There was a post about it, I think the resolution was a rubber washer from Home Depot placed overthe post and hook. Simple fixIs anyone else having an issue with the privacy screen on the trunk, i put mine back, but it falls off every drive. I tried searching on mache forums, but no one seems to have that issue.
Sorry to hear. I hope Ford can get this sorted for you right away.Thank you for asking but I have have not heard anything from Ford or dealer.
I did make several more calls to Ford but that was time and energy wasted. I am at a dead end.
I did read that there are 500 MMEs undelivered due to the seat belt recall. Ford and NHTSA swear my VIN is not part of the recall and Ford insists my car has been delivered. So the silence and frustration continues unabated.
Thank you.Sorry to hear. I hope Ford can get this sorted for you right away.
You should try car fax and see if the car was sold.Sorry to hear. I hope Ford can get this sorted for you right away.
