louibluey
- Joe
- Dec 21, 2020
- NY
- FE "Louibluey" GB
- retired
For those who have not yet ventured into the fuse box, driver's side frunk, here is a quick tour.
Below is also the part that stays with the fender. Upper left is the part that makes contact with the fuse panel 12V large flat leaf contact. The red cover is the +12V jump point that routes back to the battery by that large red wire.
I like the way the removable part with the fuses is linked by a single large sliding contact to the +12V bus. First the weather cover comes off over a set of multipin connectors.
Then, the fuse box comes off, the part with the fuses coming off the main contact, removing the +12V supply to the fuses. The now separated fuse box has a protective cover that opens like a book with a book cover.
The manual wants you to pull the two large multipin connectors, but you can just leave them on, and gently fold the wires over to gain access to finally what looks like a conventional fuse panel.
The removable panel part with the fuses must be delicate, because there is a note, if you drop this part, discard and replace it (I hate to think that that costs). The note says "SCRAP IF DROPPED". Maybe the contacts for the two multi pin connector go out of alignment?
