louibluey
- Joe
- Dec 21, 2020
- NY
- FE "Louibluey" GB
- retired
I took a first look at 12V LVB starting current today. There are certainly a lot of possible variables including seat heat, wheel heat and climate settings, not sure yet how important those are. Also, the headlights coming on might be a dominant load.
Anyway, what I am seeing on the negative black 12V battery cable is only about 2 seconds of substantial 12V battery (LVB) load, at which point MME comes on and the DC-DC converter takes over. The 2 seconds is a rough ramp to about 25A with a possible spike up to or over 50A for less than a tenth of a second. This run started from about 8A, maybe some lights were on from the last run, not sure.
On my original idea to run wires to the bumper for external starts, I am thinking now it is not worth the effort.
It is probably just as easy to always use the jump points, especially with the new idea to cut holes over the jump points.
Of course in the flat battery case, more energy is needed, because first, you have to pump enough current/energy into the dead battery to get near the 12V starting voltage.
Sample run, Each horizontal point is 100 mS, vertical axis is in current, but only valid from about -10A to +50A:
