18" Wheels & Tires on Mustang Mach-e GT Performance Edition?
mtbikemj
MJ
Carmel, IN
2022 Mach-e GT PE Dark Matter Gray
The Mach-e GT Performance Edition comes with Brembo breaks that seem to be a snug fit on the 20" wheel. Will a smaller wheel, 19" or 18" wheel fit on the GT PE? I am shopping for winter wheels and tires. Thank you for your help! I asked my dealer and they do not know.
phidauex
Colorado
Renewable Energy Engineer
18" will definitely not fit on a GT-PE, though they do fit on the other models. 19" will fit (though not every model of wheel has the same internal clearances - the stock Premium 19" wheels do fit on the GTPE with tight clearances).
mtbikemj
mtbikemj
MJ
Carmel, IN
Thank you, keeping in mind of internal clearances is another thing to consider.
UsernameChecksOut
Vancouver, BC
2010 Evo X, 2021 Mach-E GT PE
Curious if you found wheels that fit the Mach-E GT PE. I'm considering getting a set for winter tires myself (probably for next season).
mtbikemj
mtbikemj
MJ
Carmel, IN
I’m still searching, also still waiting for my order.
Chicago-E
Brad
2021 GTPE Iconic Silver, 2021 GTPE Space White
Generator Technician
I have a set of factory 19" premium wheels/tires on mine that help with range and traction in the winter. The appearance is a big down grade tho :(
mtbikemj
mtbikemj
MJ
Carmel, IN
Where did you pickup the stock wheels? How much did they set you back? I finally have a production date! Do you have any photos to share?
kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '23 BMW i4 40
I wonder if the Mach e 18" wheels would add some range back in. Thoughts or experience with this experiment?
mtbikemj
mtbikemj
MJ
Carmel, IN
In my experience as a plug-in hybrid owner, the lower the rolling resistance of the tire as well as the reduction of weight of the wheel can help with range, however it’s marginal.
tuminatr
Saint Paul,MN
2021 MME, 1964 G1 Mustang, 1993 Mustang
Sales
I can tell you I put 18" select wheels on my premium right before winter. For the few weeks when it was still warm definitely saw a bump in range. Perfect conditions though not hot enough to use the AC not cold enough to run the heat.
Mach-E-The1
FL
22 MME Premium ER RWD, BMW M5
I'm willing to trade my stock 19" for GTPE stock 20" if anyone is interested. I'm in Florida, so I don't really need the all season tires.
Scooby24
Olathe, KS
Perioperative Revenue Manager
GTPE has larger rotors/calipers and a 19" is the smallest that would fit. I believe someone here confirmed the Premium 19" would fit GTPE. The GT has the same size rotors/calipers as all the others models so it should be able to accept an 18"
RetiredDP
Camino, CA
Focus RS
That's the ONLY matter of consideration. I run my snow tires (Blizzaks) on 20" wheels, to clear the calipers.
RetiredDP
Camino, CA
Focus RS
Wrong, the GTPE has larger disks/less caliper clearance. I very much doubt that ANY 19" wheel would have clearance. Have you ever looked at the GTPE clearances?
Scooby24
Olathe, KS
