- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
I saw @SnBGC 60,000 report, and thought I'd start one for people hitting 20,000. I think it might be super useful for @Ford Motor Company to spot trends for what is holding up, and what is not. I'd suggest that if you've hit 20k miles, you post YOUR report on the good, bad, and ugly experiences with your MME.
My MME - 2021 Select AWD-SR , delivered 2/26/2021 , hit 20,000 on 1/2/2023
The good
- fun to drive, reliable mechanically, lots of positive comments on looks and performance
The (somewhat) expected
- stock tires were GONE at about 19k miles. I expected quick wear with such a heavy car, and spirited driving, but under 20k was a little bit of a surprise.
The bad
- smell of windshield washer fluid enters cabin EVERY TIME sprayer is used. Not sure if it is a leak, or fluid drain too close to cabin air intake.... but something needs to be re-designed.
- Ford Mobile Charger has a VERY weak design of thumblatch, and wrong material choice which does not resist impact. I dropped mine ONCE from waist high, and snapped off the latch. Turns out the latch is not replaceable (probably a $.05 part), so they swapped me a new charger kit.
- center display 'sticks up' pretty far, and sun from south overheated and killed my first display in a month, replaced under warranty in 1 day. Apparently has better chips inside, and I added a console protector to block direct UV exposure
- PAAK configuration at first on Android 9 phone was a bitch, but got it figured out.... failed about a year later with a major phone update that changed BT.... took a day to figure out, remove, replace, and reconfigure. works fine now again
- rear cargo support snapped off when I hit a 'speed table' with a fair amount of cargo in the back that thumped down pretty hard. Factory repair cost would have been crazy expensive and taken a couple days, so I fixed it myself. *should* be redesigned for better support in up or lowered position
- HVBJB issue surfaced for me at 18k miles..... took 2 trips and 10 days wait to Dealer to verify code and order part, I drove about 250 miles with Alert and power cap active under the SVS, and 2 days in shop to remove/replace (I was the first they had done, and they took it slow and carefully). Been trouble free since.
***current issue*** occasionally get a front camera fault, which knocks out some driver assist features. Might be a bad harness, bad connector, or damaged during windshield re-glue recall service. Will have Dealer check it out soon before Warranty is up.
***current issue*** return of the center screen going black.... just once, about a week ago. It cleared itself after I parked and came back later. NOT HAPPY this happened to my already replaced once display screen! Will have Dealer check it out soon before Warranty is up.
***current issue*** slight clicking noise from front wheel - axle area when accelerating from a stop with wheels not straight ahead. Not sure if its a bearing, CV half-shaft, seal, or what.... but will have Dealer check it out soon before Warranty is up. There is a discernible 'clunk', and some movement (maybe .060 or so) of front axles if I pull/push axially in/out toward the front motor. NO movement or clunk on the rear axles.
Turns out after a little more searching, this is a little more common than one would hope for early builds like mine, and MAYBE should be elevated to Recall rather than a SSM. ( SSM 50513 )
The Missing
- should have a tow rating, a removable Diaper access cover, and a 'blessed' rear hitch receiver electrical harness for trailer lights
- should have at least one rear tow hook under rear bumper cover
- should have at least one front tow hook under bumper access port cover
- should have clearly marked lift points, and permanent 'pucks' to make lift points obvious
The good
The bad
The Missing
