2021 Ford Mustang Mach-E: Technical Specs, Info, Wallpapers, Photos, Videos
BIGBIGSURGE
Sergio
San Jacinto, CA
2020 Tesla Model X P100D
Mine is currently in production, yet the brakes say gloss black. I got the First Edition and should have Red. Now I’m wondering if they goofed.
Advertisement
LagerHead
Marcus
Olympic Peninsula
2010 Ford F-150, 2018 Tesla Model 3 & 2 Ducati M/C
Test Dummy
I came to the Technical Specs thread hoping to find the vehicle weights for the different models as well as the GVWR's. But no luck.
Did I skip over them accidently?
Papa T
Treven
Birmingham, AL
BMW X1
I don’t think I’m actually answering your question about whether you missed that information in the Spec Sheet, but Alex on Autos posted in another thread that he reached out directly to Ford about the weights of the different models, and this was the response that he got:
https://www.macheforum.com/site/threads/alex-on-autos-10-problems-of-the-mach-e.4060/post-124147
I hope I linked that correctly. I haven’t linked to a specific post before.
kdryden99
Richard
Montreal Canada
Nissan Sentra Spec-V, Nissan Rogue, Future Infinite Blue Mach E
No it was discussed in another partcof the forum
I noticed that wheel sizes are in a variety of locations and threads, so I'm compiling all the known sizes here. Let me know if you have a size I'm missing, or a correction. NEEDED: Photos of the door jamb sticker to confirm GVWRs for the various configurations, and a confirmation on the 20" x 8" wheel offset (I'm guessing it is 38mm 53mm, but not confirmed).
✅ = Confirmed from a printed Ford document or a photo from a user.
🤷‍♂️ = Reasonable estimate.
❓ = My wild ass guess, please confirm.
Stock Wheel and Tire Sizes
TrimWheel SizeBolt PatternOffsetCenter BoreOEM Tire ModelOEM Tire SizeOEM Load Rating
Premium / First Ed. / Select 19"19" x 7.0" J ✅5 x 108 ✅47.5mm ✅63.4mm ✅Michelin Primacy A/S ✅225/55 R19 ✅103H XL ✅
Select / CA Rt 118" x 7.0" J ✅5 x 108 ✅47.5mm ✅63.4mm ✅225/60 R18 ✅104H XL 🤷‍♂️
GT20" x 8.0" J 🤷‍♂️5 x 108 🤷‍♂️53mm ❓63.4mm 🤷‍♂️Pirelli P Zero ❓235/45 R20 ❓100T XL ❓
GT Performance Ed.20" x 8.0" J 🤷‍♂️5 x 108 🤷‍♂️53mm ❓63.4mm 🤷‍♂️Pirelli P Zero ❓245/45 R20 ✅103W XL❓
Offset range is believed to be 38mm to 53mm 🤷‍♂️
NOTE: "XL" in the load rating means the tire reaches maximum load at 41 psi, rather than 35 psi for SL (Standard Load) tires.
Wheel Weights
WheelWheel WeightStock Tire Weight
18" Carbonized Grey (Select)25.62 lbs (mfg) 🤷‍♂️
19" Shadow (Select)28.88 lbs (mfg) ✅
19" Machine-Face (Premium, FE)~30lbs (weighed by member)28.88 lbs (mfg) ✅
20" Cast-Aluminum (GT)24 lbs (TireRack)🤷‍♂️
20" Premium Forged (GT)
Gross Vehicle Weight Ratings
TrimGVWRGAWR (Front)GAWR (Rear)Min Wheel/Tire Load Rating
Premium AWD ER5800 lbs ✅2660 lbs ✅3225 lbs ✅1612 lbs (98)
Premium AWD SR
Premium RWD ER
Premium RWD SR
Select AWD
Select RWD
GT
NOTE: Calculated minimum load rating is for reference only - unless you know what you are doing and why, it is best to stay at or above the stock Load Rating.
Lug nuts - M14 (14mm x 1.5mm), 21mm socket 🤷‍♂️
Photos of wheel options:
Thats what we have so far
LagerHead
Marcus
Olympic Peninsula
Test Dummy
Thank you.
But I'm mostly looking for the curb weight of the different trims. I would think that would be available by now, at least for trims that have actually be delivered to customers. I mean, it's one of the most basic vehicle specs that exist (the weight of the vehicle as delivered)!
Ford would have released this most basic and important info. It should be in the owner's manual along with the load capacities.
Am I to believe Ford is delivering vehicles without having published this data?
kdryden99
Richard
Montreal Canada
Thank you.
Well I can tell you the Select Std range RWD is 4394lbs
The Premium AWD Extended is 4890lbs
Everything else is between. For the other trims you'd have to wait until other members post it here
LagerHead
Marcus
Olympic Peninsula
Test Dummy
I don't think that's accurate. Isn't there an Owner's Manual with the basic vehicle specs listed?
The only reason I say this is the Model Y is longer, taller, wider, with wider wheels and tires, more cargo capacity, more passenger space and 50 miles more range but weighs 474 lbs. less. I know the Mach-e has 88kWh vs. the Model Y's 75kWh but how can only 13 kWh can account for huge weight disparity considering the Mach-e is a smaller car to begin with. The Model Y also crash tested near the top of any car ever tested so it's not like it's built light and flimsy.
There must be an official Ford published weight somewhere since they are actually selling the car to the public. I've never seen such a lack of basic data on any car that was actually sold to the public. It's ridiculous to have to rely on owner reports for basic weight info.
phidauex
Sam
Colorado
2006 Prius, 1997 Tacoma, 2021 MachE 4EX (someday)
Renewable Energy Engineer
I'm sure a lot of my blanks can now be filled, I just need people to do the very boring task of taking a picture of the door sill sticker on various trims. Not as fun as the rest of the car. ;)
If you find a piece of info, put a link or a screenshot into that thread and I'll update the table.
Advertisement
Advertisement
