2018 Mitsubishi Outlander PHEV GT
That would bring us a full circle about OTA update (which can be done via USB :)) for poking your nose out.
Correct again. Although OTA updates are typically done Over The Air (hence the name), not via USB.
Advertisement
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
I have been reading the owners manual in depth since it was released on the forum. Does anyone know whether the car comes with a creep mode to give a similar driving experience to a car fitted with auto transmission. I know some BEV's have it but can't find any mention of it in the manual
There is an auto hold. Possibly if not set behaves similar to creep?
Auto hold keeps you stopped at lights: When you put your foot on the brake to stop you can then remove your foot from the brake once stopped and the car will keep the brakes engaged until you depress the accelerator again.
Yes it will have creep: The Focus Electric creeped. When 1-pedal mode is off it will creep. When 1-pedal mode is on it won't creep. (of course this is my assumption--when 1-P is off it will behave like any other car.)
Shayne
Northern Ontario Canada
2021 MME4x Prem
Good shout. It's a possibility although I have auto hold on my current Kuga and it works by holding the brakes on on an incline to give you time to transfer your foot from brake pedal to accelerator.
Never needed stop and hold with an automatic transmission due to creep, would have been handy on the standards once and a while.
I inch forward at lights/traffic as the pack compresses. Not sure how sensitive the accelerator is. I would assume whisper would be less sensitive than unbridled and may work better during stop and go?
The first time we take our foot off the brake we will know if it creeps (and try all drive modes). If not I think we just adjust the idle screw on the carb ;).
Badger_Prof
Randy
Randy
I have been reading the owners manual in depth since it was released on the forum. Does anyone know whether the car comes with a creep mode ?
Despite all of the fine people on this forum, there will be some creeps who will drive the Mach-E. Even the advanced features of the Mach-E will not prevent that.
AFVolt
Gene
Winter Haven, FL
Gene
Volt
When using Auto-Hold after stopping, and you release your foot from the brake, do the brake lights turn off, or do they stay illuminated until you hit the accelerator again?
JamieGeek
I believe the manual says the lights stay on.
zhackwyatt
Reserved: '21 InfBlu Prem MMEx Current: '13 Ruby Red C-Max SEL Former: '98 OxfWhite Explorer XLT
I used auto-hold in an Explorer. Works very well. Especially at a drive-thru you don't have to keep your foot on the brake all the time. Although with electric I guess it's sort of a stop gap to 1-pedal.
Advertisement
Advertisement
