JellyBelly
- Kris
- Jun 27, 2020
- San Diego
- MME RR FE
So no auto dimming side view mirrors
Maybe not. NHTSA sets most of the safety like standards in the USA. I’m too tired to start researching trunk safety rules tonight either. I’ll wait until someone at Ford tells us if we’ve “won” the divider lottery.Sounds like it varies by state?
Made me think the car would enter a self destruct countdown.I got a chuckle at the Towing Guide page.
Just a guess, but maybe the dividers are needed until an OTA update resolves the quirks that are preventing the emergency eject button from working.Sounds like it varies by state?
I wonder how the electric unlatch mechanism works? I assume it is electrically isolated from the rest of the car because the emergency leads are simply tucked away behind the secret door in the front bumper without any method to avoid short circuit. So those leads must run directly to the latch and nowhere else.Just a guess, but maybe the dividers are needed until an OTA update resolves the quirks that are preventing the emergency eject button from working.
I believe the mirrors folded when we locked the car.The BLIS does not beep just flashes when a vehicle is detected and turn signal is on - would have preferred audio beep as well.
Has anyone figured out if the power side mirrors can automatically close when the vehicle is locked? Looks like the button only power folds them on demand - cant see anywhere if there is a setting to fold mirrors automatically when we lock and walkaway
Could it be one latch releaser that is electrically connected in parallel to two power sources? Something like this:I wonder how the electric unlatch mechanism works? I assume it is electrically isolated from the rest of the car because the emergency leads are simply tucked away behind the secret door in the front bumper without any method to avoid short circuit. So those leads must run directly to the latch and nowhere else.
That begs the question...."Is there a second latch that the on board modules can activate? "
Well thankfully, the owners manual shows in detail how to remove the front compartment filler panels so that will be the first thing that happens when I get the car home.Could it be one latch releaser that is electrically connected in parallel to two power sources? Something like this:
Circuit to open frunk using front bumper jumper leads:
front lead -> diode (1) -> NO switch (2) -> latch releaser -> other front lead
Circuit to open frunk any other electronic way:
normal 12V supply -> body control module (BCM) requests unlatch to occur -> another diode (3) -> latch releaser -> normal 12V supply
I'm not a EE. Sorry if this question makes no sense.
This is my first post with footnotes. I only attempt to honor the great @GoGoGadgetMachE with my feeble accomplishment here.
(1) prevent normal 12V loop from mixing with jumper leads; not sure if 'diode' is correct word, but I'd want something that blocks current in one direction
(2) normally open switch is held closed while 12V battery voltage is sufficient; switch opens when 12V battery voltage too low or disconnected -- this way the frunk can't be opened unless car's BCM isn't functioning (e.g. due to low power)
(3) prevent front bumper jumper 12V from reaching vehicle's normal 12V supply
I wonder if those will go away once Ford collects more data on long term fluid degradation in the Mach-e... Tesla used to have those listed as well, but long term data showed that due to lower operating temperatures compared to ICE vehicles, those fluids just weren't deteriorating. So now those fluid changes are no longer part of the maintenance schedule.- Transmission Fluid At 10 years or 150,000 mi
- Coolant At 200,000 mi
Not silly at all, actually a great question. I'm guessing that the "passive" key is something that has a chip embedded in it that requires no power to operate. Tesla embeds their chip in what looks like a credit card. You keep it in your wallet as a backup in case your phone battery dies. Some people remove the chip from the credit card and embed it in a ring. You can buy these rings on amazon. One woman actually had the chip inserted under her skin!This may be a silly question but the manual refers to remote (the key fob i think), phone as key (i get that) and passive key. What is the passive key? there are mentions of it in a few places but cant figure out what this refers to ..an electronic back up? or something else..
