What is the auto seat warmer function?
Tawna
Tawna
NH
23 Mach E premium
Hi,
What is the auto seat warmer function? Salesmen didn't know.
Womps
Sid
Alberta
2022 Mustang Mach E & 2021 Ford F-150 Lariat Super
Hi,
It will automatically turn on and off your heated seat. The warmer you have the cabin temperature set the warmer it will keep your seat. I use the auto setting all the time and there is one one thing I donā€™t like about the auto setting. I will frequently use the max defrost button in real cold weather to keep the windows clear. This automatically turns the cabin heat to the highest setting but also turns the seat heaters on to the highest setting. Well in 2 minutes the seats become uncomfortably hot.
Hammered
SE US
2022 PB F150, MME GTPE
It will automatically turn on and off your heated seat. The warmer you have the cabin temperature set the warmer it will keep your seat. I use the auto setting all the time and there is one one thing I donā€™t like about the auto setting. I will frequently use the max defrost button in real cold weather to keep the windows clear. This automatically turns the cabin heat to the highest setting but also turns the west heaters on to the highest setting. Well in 2 minutes the seats become uncomfortably hot.
Yeah, setting 3 will cook ya pretty good. It's the highest performing seat heater I've seen. Wasn't sure if the performance / fabric types performed similar throughout the line. Jeans and a Tshirt and damn it gets super hot.
axelheimer24
Axel
Buffalo, NY
22ā€™ MME Premium ER eAWD Dark Matter Grey
My car preconditions every morning with the seats on high. I love it for the first minute, then by 90 seconds Iā€™m desperate for the off setting šŸ˜‚
dj_stang
{None}
2022 MME Premium -> 2023 GTPE
Setting 3 is wild. I just wish they hadnā€™t covered the seat heaterā€™s current status when you hit ā€œauto.ā€
Before the new UI update you could be on auto and see if the heaters were on or not, now you canā€™t.
axelheimer24
Axel
Buffalo, NY
Oh no another reason to avoid that update. I can only imagine what would be going through my brain without that information. ā€œdid my car just decide to temporarily melt my ass or am I having some sort of medical event?ā€
Womps
Sid
Alberta
I can still tell when my seat heater is on in the automatic setting by a little orange indication line thatā€™s lit up and Iā€™ve had the UI update.
dj_stang
{None}
That orange indicator is lit no matter if the heated seats are on or not, it just indicates that youā€™re on ā€œautoā€ setting. At least Iā€™m 90% sure because I live in a normally temperate climate (60F+). What I see is it turn on when I hit auto (hypothesis: to indicate auto) and Iā€™ve literally never seen the light off.
Unless you have some hard evidence to the contrary.
Womps
Sid
Alberta
Hmm, now Iā€™m going to have to play closer attention, you could be correct.
Womps
Sid
Alberta
Just went out to the garage to check. Orange light is always on and seat emblem is red. As I turn the cabin heat down the red seat emblem turns white which Iā€™m guessing is off. Turn cabin heat up and seat emblem turns red.
smcnair
Stuart
Tuscaloosa, AL
F-150 Platty, Explorer Platty, '23 Premium
Wife's best friend has a Tesla X and says the seat heater is useless. That Mustang one though...cook eggs in that seat if I could afford eggs.
Tawna
Tawna
Tawna
NH
23 Mach E premium
I'll send you some eggs. My chickens are producing machines. Granted it's -43 here today and they are probably frozen.
dbsb3233
TimCO
Colorado, USA
I have to turn mine down to 1 as soon as I get in the car after doing a remote start. That's less annoying now with the new UI. Love that they finally changed the button to just tap multiple times to rotate through 3-2-1-OFF. At first I thought the update only activated the dial, since that lights up and draws your attention there. But the update also enabled the multi-tap, which is even better!
