California 2025 speaker wires
Randy 4541
Randy
La Crescenta CA
2025 Mach E Select
I'm new here. I'm adding a small 5 channel amp and subwoofer to my Select without B&O system. Non of the wiring diagrams I've seen seem to match what I'm seeing in my vehicle. I intend to splice new speaker wires into the existing ones from the ACU and run them to the LOC, RCAs to the amp, and then from the amp to the door speakers. I would like to accomplish this without having to feed new wires into the doors through the door jam. I'm open to any ideas but specifically am looking for an accurate diagram with color chart showing the speaker wires in the 2025 Mach-e Select without B & O system. Thanks.
Asr1
Ameet
West sacramento, ca
2021 mach e select SR (S.S. Darkstar)
Kinda the wrong place for this But I had luck with Pac LPHFD31 to tap to LOC from front channels and had option to wire back in to harness in future if i so desired. Instuctions are in kit. Order off amazon if connections are different easy return.
Randy 4541
Randy
La Crescenta CA
2025 Mach E Select
Oops. If you could guide me to the proper area for future posts, I would be grateful & thanks for the info.
Asr1
Ameet
West sacramento, ca
SYNC, FordPass, Forscan, OTA, BlueCruise, Audio, Soft/Firmware, PAAK, Driving Aids, Bluetooth, Cameras
Randy 4541
Randy
La Crescenta CA
2025 Mach E Select
My Mach e does not have the B&O system. Where would I connect this harness?
Asr1
Ameet
West sacramento, ca
locate Apim behind touch screen. Search mach e radio module location. Super easy to get to.
Zayy719
Isaiah
Colorado Springs, Colorado
2025 Mach E Select
Sales
Passenger footwell, pull both the front and side panel it connects to a module to the left of the fuse box. Super easy. I just installed two 12s. Easiest install i've ever done
Randy 4541
Randy
La Crescenta CA
2025 Mach E Select
Hey! Guess what? Not only did you help me figure out where the harness goes but sent me to the correct area for more feedback. Several people responded to the thread I started there and all concur with you. I found the harness and purchased the correct adapter. Can't wait to hook it all up. Thanks for all of your help.
sglewiswl
Scott
White Lake, MI
2021 Ford Mustang Mach-E Select
Have you had the chance to do the install? How'd it go and what amp did you select?
