timbop
- Tim
- Jan 3, 2020
- New Jersey
- Solar powered 2021 MME ER RWD & 2022 Corsair PHEV
- Software Engineer
The breaker should be clearly labelled with a 30, 40, or 50 on it. If your service is only 125 Amps then it is likely a 40 Amp breaker but could be a 30. I would keep the same breaker if it is less than 50, and just have the new line run. Even if the line is a 40A, with only 125 Amp service it might be a good idea to get a 24A EVSE (or buy one that allows you to set it to 24A). The last thing you want is for the A/C to come on while charging and pop the service breaker.I honestly do not know. I know it takes up two breaker spots in the panel. I'll take a picture later.
