- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
That plug is a 50 amp 3 prong (no neutral) and will work as is with an adapter. Buy this adapter or one similar and you’re all set!
ONETAK NEMA 6-50P to 14-50R 240V Compact 50 Amp 3 Prong Male Plug to 50 Amp 4 prong https://www.amazon.com/dp/B07V94TD6P/ref=cm_sw_r_cp_api_glt_fabc_0YZMD7X8479TPAMXZ31Z
It would be better to have the Installer remove/replace with the correct receptacle... a NEMA 14-50 is less than $20 at any decent hardware store. There really is no excuse for the installer not to have gotten the correct one to match your charger.
It is not a great idea to go thru adapters if you can avoid it.... more connections, more possible errors, arcing, disconnections, etc.
