A Mach-E and 2 Lightning’s walk into a bar..
sotek2345
Tom
Upstate NY
Engineering Manager
Really great picture - thanks for sharing!
ARK
Los Angeles
Mustang Mach E
Random thought - I wonder if the Mach-E would be able to charge from the Lightning while the Lightning itself charged from the grid, if there weren’t enough chargers available.
KlueBat
2022 Mach E AWD Premium, 2021 Mustang GT
You probably could as long as
1) The 240V plug in the back of the Lightning has enough capacity to power the Mach E's portable charger
and
2) The Lightning will allow the inverter to run while it is also charging
Since the Lightning is still in pre production, I'm not sure if either of these are yet known. I'm sure that someone will link a source though if they are.
Keep in mind that even if it would work, there will still be some major inefficiency involved and it might not really be any faster than if you just charged one and then the other.
Would certainly be a fun test once the media starts getting test trucks though, even if it would be very impractical.
  • Like
Reactions: ARK
ARK
Los Angeles
Mustang Mach E
and
Good points. Lightning can L2 charge at up to 80amps, so perhaps it might be feasible if it was a L2 charger capable of putting out a high number of amps (e.g., 48-80), and Mach-E was drawing only something like 32 amps, so that both vehicles could still net gain a charge if this were going on.
Mopey
Alaska
Dimwit could always take out his mobile charger and find out for us.
JoeDimwit
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
There is precisely zero chance in hell that I’m touching one of those trucks… I like getting weekly paychecks too much.
The Pro Power has a 30A outlet (L14-30) just like a generator, so you'd be limited to 24A charging or 5.8 kW. You'd need a 24A EVSE with the proper twist lock adapter, but it should work in theory. The Ford Mobile Charger won't work because it will draw too much power (32A/7.7 kW) through the outlet.
The 7.2 kW max output comes from using multiple outlets at the same time throughout the truck.
  • Like
Reactions: ARK
I can’t wait for ford to put a tow strap on a cyber truck and crag it all over the Mojave with one of those ???
and
It’s already been confirmed that the Lightning will allow the inverter to run while it is charging.
Video was posted here a while back off an F-150 hybrid charging a MME off its Pro Power system.
  • Like
Reactions: ARK
KlueBat
Oh, cool! So now we need some test vehicles to see how much faster or slower it would be to daisy chain chargers vs just charging the vehicles separately.
  • Like
Reactions: ARK
Davedough
West BYGOD Virginia
Mach E GTPE , Explorer ST
Federal IT Sales Engineer
Well that pic all but confirms one of those wouldn’t fit in my garage. Still would like an EV truck though
JoeDimwit
JoeDimwit
Waterford
Electrician
Could you bump out the back of the garage a bit?
Alternatively, you could notch the garage door… ?
