sukhoi_584th
- Sep 29, 2021
- United States
- 2022 MME CR1 AWD
I learned today that a new co-worker was previously the reliability engineer for contactors on a well known EV, so I picked his brain. Most of what people have been discussing here is correct but there are definitely some misconceptions.
Background:
Welding closed:
Background:
- Despite what suppliers say, contactors currently in use were not designed for this use case. They were designed for industrial electrical cabinets, motor controllers, etc. where they are under constant load. They are one of the last components to be properly redesigned for the transient loads of EV use.
- The basic design is a solenoid pushing a plate against the two pins to close the switch. The contactor is made up of the pins, plate, housing, potting materials to seal it, and it is filled with gaseous nitrogen to prevent arcing (this is key).
- They do not open/close under load, ever. The exception is e-stop type usage.
- This table is not applicable to EV usage. The red circle is where we are at for EVs. The table is intended for e-stop type usage on industrial equipment so you know how many times the e-stop can be done before expecting the contactor to fail.
- Solenoid current usually varies between high current to close the contactor quickly, and a maintain current to hold it closed. This is what the "economizer" does. For a vehicle with multiple contactors like the Mach-E usually an external optimizer as part of the Battery Management System is used to control all the contactors to save money over integrating economizers into each contactor.
Welding closed:
- By far the most common failure mode (vs failing open). Pitting leads to welding.
- There are a lot of different materials with different coefficients of thermal expansion in a contactor. These include the copper pins, potting material, and housing. Excessive CTE mismatch when the pins heat up causes cracking/leaks, the nitrogen vanishes, and pitting/welding quickly follows.
- DCFC is hard on contactors as it causes the copper pins to heat up the most and imparts the most thermal stress.
- If the economizer is not tuned properly the contactor can close too hard with the plate bouncing/vibrating off the pins, and cause arcing. Additionally the pins are usually a harder material than the plate and can cause physical deformation of the plate if it closes too hard.
- Rare and unlikely to be a hardware failure. It is probably software-commanded where the software thinks there is a dangerous high voltage fault and cuts off the battery immediately. Likely Ford was being very cautious about this, and the recall software update makes the software less likely to falsely identify a HV fault.
- The solenoid coils could be failing or there could be a problem with the electronics providing power to the coil.
- The contactors are probably leaking nitrogen then arcing. They are being used in a harsh use case with heavy transient loads very different than industrial motors. Industrial motor controllers are also not under pressure to reduce cost by pennies and more likely to be over-specced for the application vs our DCFC loads being close to the max allowed by the contactor.
- There may be minute product differences causing what worked fine during Ford's testing to now be failing. My co-worker had a supplier move production from one factory to another, and the contactors went from fine to failing after only a few thermal cycles. They eventually had to redesign the contactor to eliminate the failure mode as they couldn't figure out why the ones from the new factory kept failing.
