sunkid
- Jun 11, 2021
- San Diego, CA
- 2021 Premium RWD ext. range
Like a few of you, I couldn't wait to install a dash cam the first weekend I had my shiny pon-e in the driveway. Following the excellent tutorial by @MachDoc , I tapped into fuse #4 (see image below, "borrowed" from that post) for a constant-on installation of a Vantrue N4, which worked like a charm.
As the weeks went by (has it really only been 3???), I was loving driving the car, software quirks and all (current trip not resetting reliably, one spurious but scary "powertrain malfunction," a couple of "no chargers in range" warnings, etc.). I figure, eventually, Ford will address these with an update.
However, what bothered me "from the start" was that my key FOB had a very low range and that walk-up unlocking or walk-away locking did not work reliably. I tried both FOBs and replacing the battery of one to no avail. I also tested with just the FOB in my hand and not in my pocket with my wallet (I ended up replacing the strong-magnet-containing wallet anyway even though it didn’t make a difference). My last, desperate thought before talking to the dealer was that maybe the dash cam is blocking the sensors or that the cables that I had stuffed into the mirror housing were somehow causing electromagnetic interference. Sure enough, as soon as I unplugged the camera, my FOB worked well and the car reliably locked and unlocked. I then eliminated one possible cause after another: I removed the camera from the windshield, pulled the cables out of the mirror housing, and unplugged the rear camera, but the only thing that cured the range and reliability issue was unplugging the power from the camera.
So I moved the camera power to the #24 fuse (25 A) and all was fine (that fuse is also constant on).
