- Mark
- Nov 13, 2019
- Sonora, CA
- _______ '20 Shelby GT500 FPB '21 Mach-E GTPE IS
- Retired
Hi Tanner, thanks for the complements. In the 8 months I had the premium, I had no issues with the 12 volt battery and don't really see why I should. I just installed the same sub in my GT which I have only had a couple of weeks and did it exactly the same way as in the premium. I have in past cars like my Focus RS and Escape, installed a small aux battery in the cargo area for the audio system but that is usually only when I have multiple, high powered amps running the entire system. The amp in the JL Sub is very efficient and doesn't require it.@markboris awesome write up! It looks like you really know your stuff here. Do you have any concerns with the low voltage battery? I see a lot of threads (at least older ones) with 12V battery drain issues. I was thinking the added draw could be a concern, but from your experience after install have you had any problems?
Also, do you see any benefit from the remote volume knob? I wasnāt sure if the built in equalizer controls on the Mach-E display would be sufficient to adjust bass output without it, or if thereās a drawback to doing that I donāt know about (gain vs volume sound quality loss?). I had a setup in my last vehicle similar to this and probably adjusted the volume on the sub once or twice but in general kept it after I found my sweet spot, so seeing if itās worth the added cost.
About the remote volume control for the JL sub, I feel it is an absolute must. Adjusting the bass control of the equalizer setting in Sync is completely different as it seems to be more of a mid-bass control and centered around 125 Hz and will affect the bass in all the door speakers too. Using the JL remote volume control will only adjust the volume of the sub which is of course a much lower frequency and more centered around 50-80 Hz depending on where you set the crossover on the sub. I frequently adjust the volume of the sub (the reason I always mount the control in a convenient location) depending on the type of music I listen to. Many older classic rock tracks don't have a lot of deep bass so I boost it a bit while newer pop and electronic music, have quite a bit and may need to tone it down a bit. You can always install it later but it is much easier to do it at the same time when running the power wire to the rear..
