Always over it. The Dynaliner is for the metal and the Dynaliner foam is for sound. It eliminates the echo and audio reverberation inside the doors.Ok. Do you install dynaliner on or under dynamat?
If you are talking about adding the sub, I have that info in the first post of this thread. I'm traveling today (driving) so can't make up a quick list right now but many others have done this and might chime in. Very few parts/wiring needed.I am going to get all stuff to do the upgrade. What wires and other hardware do I need ?
Hola Juan, sí puedes instalar el miniamplificador JL sin el amplificador B&O pero requiere otro dispositivo y es más complicado y cuesta más dinero. A menos que planee cambiar todos los parlantes y realizar una actualización importante, sugeriría agregar solo el miniamplificador JL al amplificador B&O.¡¡Hola a todos!! Mejoraré el sonido añadiendo JL 12' Sub y mini amplificador JL 280/4.
Veo que Mark agregó el mini amplificador Jl al amplificador BO. ¿Pero he leído sobre la instalación de este amplificador Jl 280/4 sin amplificador BO?
Did you change the BO amplifier for the jl280/4??? Was it difficult for you to make connections?See the attached instruction page for connecting the JL 280/4 amp... points 2, 4 and 5 should answer your question.
Happy New Year!
I did. It took a bit of time. As I recall, 16 or 17 separate wires to cut and then to reconnect. I used PosiLock connectors throughout and that helped a lot with the overall speed of reconnecting and also with the assurance that the new connections were solid and durable.Did you change the BO amplifier for the jl280/4??? Was it difficult for you to make connections?
Hi. Because I had a shop do the work, I don’t know the specific details for the questions you’re asking. Sorry about that.I have already installed the jlaudio 12 subwoofer and I still have to install the jlaudio 280/4 amplifier.
where have you taken the 12V? Regarding speaker cables, there are many since there are 4 stages. In which cables of the BO amplifier have you inserted the cables? Regarding the rem cable of the jl280/4, where have you connected it? I understand that it is to wake up the amplifier. Thanks for your help, I'm looking forward to finishing the feat.
I would... it's meticulous yet not hard and completely worth it. See my pic of the result.Thank you for your answer
21st Century Pony
Okay, I won't remove the BO amp. But I need to know where to connect 12v from the jl mini amplifier and the rest of the audio cables. Are those cables inserted into their BO amp equivalents?
Hi Harrison, if you mean the fuse for the main 12V+ cable that is at the battery, yes you need that fuse. If that cable should ever short to ground, the fuse will blow otherwise without a fuse you could have a real issue on your hands.@markboris This is a super clean install, and it looks like you have helped alot of people, that awesome! I have a quick question for you? Im installing a system that can take 12-24v do you still recommend the fuse from the 12v to the system or do you think I can skip it? Also any concern about the system staying on and pulling from the 12v?
