WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
WARNING
Read
THIS thread before attempting any of these recall remedy updates.
New updates posted in FDRS. I am still traveling so I will update this post as others report. (GWM and OBCC are from earlier in the week Thread Link)
Ford Mustang Mach-E !NEW WARNING!: All Vehicles - PCM, BECM, SOBDMC, SOBDMB Updates available in FDRS 1656160935913
Job 1 and 2022 have an additional SOBDM update.
Update Details
There is no confirmation that this update package is the one which will address the recall.
Regarding version numbers and the recall notice, it is possible that the SOBDMC listed in the "Remedy Component" list is a typo (as the same versions appear in both the recall and remedy component sections) and that this new version is actually the correct "Remedy Component" number.
BECM
The version being installed is the version listed in the Remedy Component section:
Standard Range: NJ98-14C197-AE
Extended Range: NJ98-14C197-BD
GT/GTPE: LK98-14C197-CG (No GT/GTPE versions are listed in the recall and remedy lists)
SOBDMC
This module has a lot more versions and the list below is a compilation of thread feedback and checking of available VIN numbers. EU versions are different and are obviously not referenced in the US recall notice.
2021
SR/ER AWD/RWD - New version is one version higher than **G version in remedy list. As with BECM, GT/GTPE versions are not listed in the recall and remedy lists.
SR AWD (EU): LJ98-14G069-AVH
SR AWD: LJ98-14G069-AXH
SR RWD: LJ98-14G069-AZ(H?)
ER AWD (EU): LJ98-14G069-BAH
ER AWD: LJ98-14G069-BBH
ER RWD: LJ98-14G069-BDH
GT: LK98-14G069-BM
GTPE: LK98-14G069-CM
2022
No versions match recall notice
SR AWD (EU): NJ98-14G069-A*
SR RWD (EU): LK98-14G069-C*
SR AWD: [Need feedback or VIN to check]
SR RWD: NJ98-14G069-M*
ER AWD (EU): [Need feedback or VIN to check]
ER AWD: NJ98-14G069-VB
ER RWD (EU): NJ98-14G069-RB
GT: NK98-14G069-UC
GTPE: NK98-14G069-
UPDATE 6/28/2022
Ford has published that the PCM, BECM, and SOBDMC versions currently available on FDRS will remedy the recall. The bulletin and tech/installation info are available here
NewGuy
NJ
Ready to order
Is this THEE update? (Related to the recall.)
Logal727
C
Hope y’all like OTA inhibit updates!
WyldStallyn
Jody
New Hampshire
2021 Mach-E GTPE
What that mean
@Logal727 is referring to OTA's which inhibit using the vehicle during the update. This thread is about FDRS connected updates which by nature prevent use while updating but when these updates come OTA they will likely be inhibit updates.
KevinS
Thanks. My vehicle has never received an OTA update so in my info 'Inhibit Status' is listed as 'null.' I never knew what it was for but your explanation is very clear and makes perfect sense.
Gimme_my_MME
Dearborn
Hey! Get out of here with that polite and reasonable response
PeeKay
Pravin
Sunnyvale, CA
2021 Job 1 MachE
Doesnt the OTA server skip the download, if the vehicle reports the updated versions back? Thought I read that on some other thread.
chrisGT
Northern California
2021 Ford Mach-e GT
Updated. All ok AWD Job1 Europe. 40 min
Can you check the versions to see if they match the ones in the recall notice?
"The updated SOBDMC software (LJ98-14G069-AXG, LJ98-14G069-AZG,
LJ98-14G069-BBG, LJ98-14G069-BDG)
will monitor contactor
temperature and intelligently reduce battery power to prevent damage to
the contactor. The updated BECM software (NJ98-14C197-AE,
NJ98-14C197-BD
) will monitor contactor resistance to identify an
overheated contactor and reduce vehicle power to prevent further
damage"
dreKion
Alfonso
Spain
Mach E AWD ER+
NJ98-14C197-BD
damage"
BECM: NJ98-14C197-BD
SOBDMC: LJ98-14G069-BAH
