I went down to 32 psi cold and as measured by an external gauge. Often the car reports 33 or higher, especially when driving. I put the rears at 40 psi cold. I have found the lower pressure in the front makes the ride a lot smoother. But it does not reduce the bounce.You might air down a little. Some other users here are going with low 30s psi up front to smooth out the ride. Paging @mkhuffman...
