Alternative to Accent Lighting - Automobile Moulding Line
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
2021 Premium MME 4EX Star White, 2019 Acura RDX,
BSI Sales and Technical Manager
There is a thread about adding neon rope for accent lighting but I don't think many MME owners will try that. I have found an alternative that most of us can do. It doesn't light up at night but stands out brilliantly under most lighting conditions, even a dim glow. Over 95% of my driving is during daylight hours so I get to enjoy the added ambiance for a much longer time than powered lighting would give me. $13 worth is enough to do more than four interiors:
https://www.amazon.com/dp/B08P7HG59Q?psc=1&ref=ppx_yo2_dt_b_product_details
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036061450
To go around the corners of the instrument panel, I cut out v-sections so that the material would bend.
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036162993
The included tool is wedged first ahead of the strip to make the installation much easier.
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036291790
The kit comes with two rolls of the material and two tools. The tool won't fit in the area behind the steering wheel so I put the second tool in a vise and while heating it with a heat gun, bent it to about a 45 degree angle so it could be used in that area.
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036462315
I used two sections of strips that ran 2" behind the center screen on each side (it can't be seen that it doesn't run all the way across in one piece). The result exceeded my expectations.
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036509884
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1640036538642
Rebelchopper
Columbus GA
2010 F150, 2013 Santa Fe, 1968 Mustang, 2015 HD
Jet engine quality inspector
Looks great! I'm one of the few that's actually going to do the neon rope (EL wire).
B25Nut
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
I added it to the doors yesterday.
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1642451878814
Ford Mustang Mach-E Alternative to Accent Lighting - Automobile Moulding Line 1642451916431
Morbeious
Mach-e GT Performance 21
Tech
I like it.. I'm looking for one that I can change the color long with the interior lights.
AJ_Glo
AJ
MKE, WI
74’ DeTomaso Pantera
Auto interiors designer and ambient lighting integrator
Hit me up I have access and supply the aftermarket with the actual OEM flexible glass fiber optic LED lighting solution you all seem to be looking for
Be careful it’s very risky putting EL into a car due to the AC/DC conversion EL buzzes, starts fires, and dies out/fades dramatically within 2-3 years
AJ_Glo
AJ
MKE, WI
262-261-3390 AJ cell please don’t abuse
doogie63
NC
Mach-E
Looks good. Adds that extra pop to the interior. I like the blue, goes with the blue car.
