Always charging to 100%
HoosierMME
Bloomington, IN
2022 Premium AWD ER
In the FordPass app, I’ll change the settings in the Charge Settings to charge to 80% while at home on my L2 charger. I then hit save, and it acts like it’s updated the settings, but then it will still display that it is charging to 100%. It does in fact charge to 100%. Do I need to remove and install something again?
Do the setting in your car. For some reason FP doesn't always save it correctly.
AKgrampy
Fairbanks, Alaska
Did you also select “use preferred charge settings” on FP?
tbrumleve
Tom
Oregon, USA
Update the app. The latest update fixed a few things. Otherwise, change it in the car.
HoosierMME
Bloomington, IN
2022 Premium AWD ER
Thanks! I’ve actually never set the limit in the car before. Hopefully it’s not buried too deep in the menus.
AtomicInternet
SC
Focus RS, Mach E Premium
It's actually in the charging app. Make sure "preferred charge times" is turned on and then click the pencil next to it to change the settings.
Ford Mustang Mach-E Always charging to 100% PXL_20240105_113940909
dgilles428
Peoria, IL USA
21 Mach-e GTpe, Corsair, Ford T350HD,Monster Miata
retired IT manager
I had this problem until someone here said to make sure "charge when plugged in" was turned off .. has worked great since I changed that.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
Always set it in the car and you'll have no problems.
ocdxfv
Matt
Orange County, CA
Retired radiology tech
"Always set it in the car and you'll have no problems."
I had the 22S41 (battery energy control module update) AND the 23B50 (charge cord stuck reprogram) completed yesterday. When I got home and plugged in, the car started charging to 100% immediately, which wasn't supposed to happen. Turns out the update(s) lost my charging location and settings. I was able to reset my home location and the % of charge, but wasn't able to set a preferred charging time from the car. However, I was able to set the preferred time on the app, and the car now reflects that change. I guess if one doesn't work, try the other.
HoosierMME
Bloomington, IN
2022 Premium AWD ER
Thanks for all of the advice. Finding all of the settings wasn’t as obvious as I would have assumed. Turning off the Charge when plugged in, seemed to do the trick for me.
