AM Radio on a ‘23 MY GT
intensifi
Jeff
San Mateo
GT
After the 6.8 and 6.13 updates when I start the radio app the lowest number AM station shows up.
However only FM and Sirius are choices up top!
Because of this, the only way to get to AM on a consistent basis is to scan to a station you desire and then make it a preset. In theory these aren’t going away anymore.
Once you choose an AM preset, AM is selected and you can scan or direct enter a station number as desired.
Looks like the software isn’t quite finished.
dj_stang
{None}
2022 MME Premium -> 2023 GTPE
Interesting so AM actually works on your ‘23? I enabled mine in FORScan but I’m pretty sure my car is missing the actual module.
If yours has the module then it’s a simple parameter to change in FORScan and you’ll be able to use it normally.
intensifi
Jeff
San Mateo
GT
Ya it works!
Auto Motive
Doug
Valencia Pa
AM? In my area its religious or maga rantings.
Auto Motive
Doug
Valencia Pa
Sports. Giants baseball games defines my need for AM radio
Now that you mention it our pirates are on AM but the station has a FM station also. 1020 am and 100.1 FM. Interesting.
O’Msjestic1
Robert
Hondo. Texas
2020 F250 Limited Diesel, 2017 F250 Lariat Diesel,
November ‘22 GTPE, Yandu. AM sounds like an old school oscilloscope when the blinkers are used and I have on our local clear channel 1200 AM. I fixed the interference with a manual filter. Me. I stopped using the blinkers.
No issues with the June ‘22 Platinum Lightning other than static on every AM channel when running parallel to overhead powerlines.
I don’t know what the fuss is all about.
intensifi
Jeff
San Mateo
GT
If the cars came with lifetime SiriusXM I would not care. But dealing with the SiriusXM call centers is so profoundly disturbing that I will never do that again. Thus AM is fine for local sports that are not on FM.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
In my area in CT the AM stations have stronger signal range then FM. Yes, used for listening to sports here also.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
I recently found SiriusXM ok to deal with on the phone. We cancelled service on one car and downgraded service on the MME. Offers flew but I just said no,no,no,no,no. They did what I wanted.
adaminca
Adam
Santa Maria, CA
2023.5 MME GT Performance
AM radio quality is not a unique problem to the MME. I had miserable reception on my 2017 Fusion Energi as well. I solved the problem by using the TuneIn radio app installed on my phone. It is easy to set favorites then you can quickly select the desired station via Carplay (assume it works as well on Android phones).
ArthurDOB
Arthur
High School Teacher
Fellow Giants fan! Been one since 1971. Went to San Mateo HS. Go Bearcats!
Back when we first moved out here KGO was stil a real radio station and had the 49er games. Listening to them on an atmospheric skip was a hoot. Then the internet happened and that all became unnecessary. So no am radio needed for me any longer. ;)
