epec
- Wensen
- Mar 11, 2022
- Houston, TX
- 2019 Ford F150, 2022 Ford MME
I do not think this is uncommon topic here, might be. had my 2022 MME for 7 months now and have put 12k miles on it, most charging was done in office due to daily commute and might be once a week charge in garage with mobile charger from Ford. When Texas gets into summer (low 90s) now, since three weeks ago, I realize the amber light was on when car was in charge for more than 30 mins, the rate dropped to 5kW but seems still be able to put 25 to 27 miles per hour as amber light was on and out (my guess it reduces the charging rate and it cools down). i touched the charger and plug to wall outlet, it is a little warmer but definitely not hot at all. the plugger is cooler than the charger box for sure. I brought the charger to dealer, they replace it with a new one. As I installed NEMA 14-50 myself, I went back to check the connection, all solid and tight connection. used the new charger, when the garage door was open with air flow, first one hour has no issue, but once I close the garage door, within 30 mins, the amber light is back on and off, charging rate varies between 5kW and 7KW. seems it is charger issue but anyone has similar issue to charge the car during summer (we are not really in peak heat yet). wondering whether I should spend couple of hundreds dollar to buy a L2 home charger or keep using this ford mobile charger.
also I used industry grade NEMA 14-50 , 6AWG wire, 50A CB, so I do not think it would be the circuit issue. the cover plate was never warm
