AOSK Mach E Frunk Mat, 3 Different Versions, one of them gotta be the one you like.
AOSK
Diamond Sponsor
Zac
california
Mach-E select
AOSK currently has 3 different frunk mats either in stock in the Amazon warehouse or on the way to the Amazon warehouse. let me introduce them to you one by one.
First one, simple design one piece frunk mat.
One Piece(without divisor) (IN STOCK)
The design of it is clean and simple, designed for owners that removed the OEM frunk divisor
Ford Mustang Mach-E AOSK Mach E Frunk Mat, 3 Different Versions, one of them gotta be the one you like. 61miNtk4ROL._AC_SL1200_
The second one, Frunk Mat with divisor
Frunk Mat with divisor (IN STOCK IN 3 DAYS, ALREADY ARRIVED AMAZON WAREHOUSE)
Designed for owners that want to keep their OEM frunk divisor.
Ford Mustang Mach-E AOSK Mach E Frunk Mat, 3 Different Versions, one of them gotta be the one you like. 615pyDOs2ML._AC_SL1200_
The third one, OEM Style Frunk Mat
(on the way to the amazon warehouse, expect 20-25 days)
Designed for owners that want your frunk mat to match your OEM floor mat
Ford Mustang Mach-E AOSK Mach E Frunk Mat, 3 Different Versions, one of them gotta be the one you like. 61ZQJJKa8nL
Which one would you pick! let us know your thought, then we will send more inventory to amazon warehouse.
markboris
Sonora, CA
Hey Zac, I like the looks of the last one. It also matches your trunk mat and rear seat back covers.
markboris
Sonora, CA
and it match the oem floor mat as well
Yes they do but I don't have nor do I need all weather floor mats. I only have your trunk mat and rear seat covers because my doggie travels with me a lot.
I think probably the last one. All of them seem to block the drain plug though. 99% of the time that should not be an issue though. They’re not listed in your Amazon store yet though?
How about a version 4: like version 3 but with an opening over the drain hole?
markboris
Sonora, CA
While it would be no big deal to make your own hole, if I ever did put something in the frunk that needed draining, (which will probably never happen) I wouldn’t have that mat in there anyway.
Mach-E Premium 4X, F-150, Lightning reserved
I get having a trunk mat in every vehicle. And I have a mat in my F-150 to protect the bed because I hauled a lot of junk in it (and even with a thick rubber mat have some minor dings in the bed).
I understand those without Ford frunk dividers maybe wanting a mat if they were concerned about things sliding around in the frunk. But I guess I don't see the need for a mat otherwise. If I had items that I was worried would gouge the frunk up, I would put them in the trunk and tie them down, because if they're going to gouge the bottom of the frunk they'll likely gouge the sides also.
As to the one with the frunk dividers installed, hopefully the separate pieces work together and hold the shape if one removes the dividers?
That said, the price seems fair for the one.
These looks great. But some of us took out most of the dividers, but left one side in. For example, I left the passenger side divider in place so that I have one small side and one large side. I don't suppose there's any plan to make a version that would fit in that scenario?
Do you mind posting a picture? This sounds like a great way to keep the wing sauce separate from the shrimp cocktail.
Sure, here ya go. I worry that the divider may not be impervious to sloshing wing sauce or shrimp cocktail though. I guess we'll have to try it.
Ford Mustang Mach-E AOSK Mach E Frunk Mat, 3 Different Versions, one of them gotta be the one you like. 1646059302407
Mach-E VLOG
Patrick
Denver, Colorado
machevlog.com
Cool. Thanks. I might try that.
Lord Polymath
Arkansas
2021 Sienna, '22 Mach-E Premium ER AWD (PWRPONY)
Computer nerd
Just to confirm, 2022 models no longer come with the dividers, correct? A shame, I like generaltso's small and big compartment idea.
Correct. But there are enough people on here that removed them that I bet you could get your hands on some pretty easily.
