Jank
- Jim
- Dec 28, 2020
- North Carolina USA
- Q5, Suburban, CR-V, Sprinter, mach-e
Some classic parts of the article:
Quality and customer service have been consistent Tesla weak points. And when new investors gave the company a sudden windfall this year what did they choose to spend it on?"If you open the hood on the front of Tesla, you can see where it's painted and not painted. It's like a blue and then a taupe or a weird color in between. ...
... I had a 2019 Model X 100D, I used to hit a puddle and water would shoot up from the dashboard .... People actually told me maybe you shouldn't hit puddles and I was like, 'Are you kidding me?' ""
Many people don't realize regeneration only turns about 30% of the momentum it removes back into energy stored in the battery. Yes, regen is great, but only when you are intending to slow down. Unintentionally engaging regen, which is unavoidable with 1PD on the freeway, is quite wasteful. Both the Taycan and MME coast with no or very little regen but do apply regen when the brake pedal is first touched. The key is to avoid using so much brake pedal that the mechanical brake is applied....
"You can turn off the regeneration and, if you're going down a hill, the car will do almost a neutral phase, just let it roll. You can coast to 80 mph. ...
I think some of you do not understand about regen and OPD. You don't just take your foot all the way off the pedal going downhill. You just back off enough to maintain your speed. Just as you do in a ICE. But, say you are going down a very long steep hill. IF you back off enough to control your speed where you want then instead of having to tap the brakes and lose ALL of that kinetic energy you can back off to let it lightly regen to keep your speed where you want. The trick is teaching yourself to never use the brakes except for emergency braking. For example: we drove about 150 miles in our Leaf today to do some shopping the wife wanted to do. I can honestly say I did not brake a single time in that mixed highway and city driving. About 40 miles of that was driving curvy mountain roads where you would normally be riding your brakes all the way down the mountain (unless you had a manual). Instead of wasting that potential energy as heat in brakes it probably added about 10 miles of range back in to the car. Learning to use OPD is like learning to operate a clutch and gear shift. You get good at it with repetition.Many people don't realize regeneration only turns about 30% of the momentum it removes back into energy stored in the battery. Yes, regen is great, but only when you are intending to slow down. Unintentionally engaging regen, which is unavoidable with 1PD on the freeway, is quite wasteful. Both the Taycan and MME coast with no or very little regen but do apply regen when the brake pedal is first touched. The key is to avoid using so much brake pedal that the mechanical brake is applied.
Probably built in the tent in the parking lot Not hugely out of character for Tesla, they seem to have completely skipped the "building a car" part of car building, and gone right to software."Look, when I had a 2019 Model X 100D, I used to hit a puddle and water would shoot up from the dashboard in my car.-----
WOW! Never hear this one before and it is shocking.
there's a lot of positive stuff for the Mach-E in there. some nice Tesla comparisons, other Ford comparisons like to hybrids and Energis, etc.
Dead wrong. using the brake pedal in any EV I have driven or heard or progressively adds more and more regen before applying the mechanical brakes. Some cars provide a more 'natural' feel than others, but all work this way.... instead of having to tap the brakes and lose ALL of that kinetic energy you can back off to let it lightly regen to keep your speed where you want. The trick is teaching yourself to never use the brakes except for emergency braking.
agreed, I have a 5 year old Fusion Energi where I rely heavily on the regen braking. I live by a lot of hills where my ICE vehicles require new brake pads every 2 years. I have never needed to replace my brake pads on the fusion. And it is my daily driver. I love watching the battery charging as I am going down the hills.For example: we drove about 150 miles in our Leaf today to do some shopping the wife wanted to do. I can honestly say I did not brake a single time in that mixed highway and city driving. About 40 miles of that was driving curvy mountain roads where you would normally be riding your brakes all the way down the mountain (unless you had a manual).
and fords even train you how to do it with the brake coach. Most of my stops are 100% which assume means all regenDead wrong. using the brake pedal in any EV I have driven or heard or progressively adds more and more regen before applying the mechanical brakes. Some cars provide a more 'natural' feel than others, but all work this way.
BTW: the regen/brake blending was initially sold by Toyota in the first Prius. This is how all hybrids work too.
The Toyota RAV4 hybrid 4wd system has a third motor-generator and this adds charge to your battery pack at a much greater rate than the typical hybrid MG1-MG2 drive system. My RAV4 more than doubles the amount the CMax PHEV does.Dead wrong. using the brake pedal in any EV I have driven or heard or progressively adds more and more regen before applying the mechanical brakes. Some cars provide a more 'natural' feel than others, but all work this way.
