B&O center speaker replacement
WylieRu
Dallas
2021 Mach-e ER RW
My center speaker was blown and the dealer told me I would have to drop my car off for 5-7 days just to look at it. So I order a Kicker 3.5in dcs35. It fits in the stock hole without any mods, it’s a really tight fit so I just screwed each side down a little at a time until in went all the way down. I also reused plug off the old speaker and soldered it to the new one. The plug was held in place by a screw on the old speaker so I just glued it to the bottom of the new speaker after I was done with the soldering. Sorry I didn’t take any pictures.
How does it sound?
WylieRu
Dallas
2021 Mach-e ER RW
It hard to compare because The speaker was blown for a few weeks. Sounds good to me, very clean and clear when it’s set to surround
RedStormREHS
Martin
So Cal
Toyota Camry Hybrid / Toyota Sienna
Health Inspector
Yep. I was in this club too! Bad front, center speaker with B&O system. Sounded awful. Dealer changed it out easily under warranty in a couple days. Weird how one speaker just went bad in less than 1yr!
breeves002
St. Louis, MO
2021 Mach-E GT PE
I don't recommend replacing the speakers with aftermarket unless going aftermarket amp. The DSP of the B&O system expects very specific speakers. Allows them to use $3 speakers and still sound decent. Center speaker may not make much of a difference but the door speakers will most likely sound worse if replaced.
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
I hear this is common. Good post. You must have used surround mode a lot.
MyLittlePony2022
William
SF Bay Area, California
I was researching replacing my speakers, and I have purchased new Infinity Kappa for the dash and doors. I am not replacing the center channel speaker. I prefer the stereo mode. I took apart my center speaker and took pictures as part of my investigation. See attached for reference.
The reason your 3.5" speaker was tight was that the opening for the speaker is 3 inches and a typical 3.5 inch speaker has an opening around ~ 3.125 inches.
Heh, I was waiting to see a response from @MyLittlePony2022 since we talked about this subject last weekend. ??
I still am expecting to see rainbows and sparkles every time I think of your screen name.??
MyLittlePony2022
William
RobC86
Robert
Temecula
Mach E GT
Military
For those who replaced their center speaker on their own, was the cover a pop off or did you have to unbolt anything that I am missing before having access to the speaker?
I haven't had to (nor want to) replace my center speaker but the cover pops off. There are just clips underneath.
From the Ford repair manual:
Ford Mustang Mach-E B&O center speaker replacement Screenshot 2023-08-27 at 5.45.57 AM
Ford Mustang Mach-E B&O center speaker replacement Screenshot 2023-08-27 at 5.46.15 AM
Ford Mustang Mach-E B&O center speaker replacement Screenshot 2023-08-27 at 5.46.27 AM
RobC86
Robert
Temecula
Mach E GT
Military
So I’m looking to take the same route since the speaker is now back ordered until an unknown date. Clearly still an ongoing issue. I just want to validate the speaker you chose because crutchfield says it doesn’t fit the Mach E. I’m finding Kicker 43DSC3504 based on what you shared. That accurate?
WylieRu
Dallas
2021 Mach-e ER RW
that's the one
