Iām not too impressed with it either. However, if you set the fade to a bit more in back and bring the bass & treble up it helps.B&O sound system does not sound all that great in my mach e
It sounds good, but I don't know could be better for a brand.
I feel like the bose system in any car sounds better. I have all the sound settings to normal.
am I missing any setting
I'm inclined to agree with you there, bud. The Bose in a regular Tahoe (which I've had as a rental recently) sounds better than the B&O in our Mach-E. Coincidentally, we also have a Expedition Platinum with the B&O sound. Same disappointment.I feel like the bose system in any car sounds better.
^^ All these things.I donāt know how old and/or updated your Mach-E is, but there was a DSP update a while back that improved the sound quality. Itās not the best car stereo Iāve ever had for sure, but itās passable.
I found that setting the sound to āSurroundā over āStereoā helps a lot; it sounds much better in surround mode. Also, the input quality makes a huge difference. SiriusXM always sounds like trash because of the compression, but if you play something from Apple Music via CarPlay, for example, it can sound greatāwith the exception of heavy bass which the Mach-E just canāt muster with stock gear.
If you havenāt gone in for the updates, that might help.
FYI the system is DSPed for the stock drivers, if you replace the loudspeakers the tonal qualities will be off since the DSP being applied is wrong. It requires an aftermarket DSP as you said to actually realize a tonal improvement.I am in the process of replacing my speaker with Infinity Kappa's and will post a new thread when I am done with write up and pictures. I have the right driver door done and will be working to do the rest this weekend and probably into the next few weekends. Based on what I can hear from just the two speakers that I have replaced, the aftermarket sound better. However, I think that an aftermarket amplifier with a DSP is required to take it to the next level and really tune the sound. I am heading that way but just waiting on a sale at Crutchfield on a 6 channel AudioConrol amp.
