memcm_expert
- Randall
- Oct 4, 2020
- Washington
- Mustang Mach E FE Carbonized Grey
Good Evening All,
I have come across a bad, and very annoying, bug with Bluetooth and at least iOS in the Mach E.
If you are in a call when you get in the car and start the car, you can continue with your conversation, but not over Carplay, but over the Bluetooth connection to the Mach E. When you end the call, you can no longer use Carplay OR the Bluetooth connection to the Sync system. It will remain this way until you turn the car off. I tried turning off Bluetooth on my iPhone, tried disconnecting my iPhone from the Mach E via on Sync System, rebooting the phone and everything else I could think of. Only turning the car off exiting the car locking the door and then re-entering the car would resolve the issue. Or, the more radical fix, perform a reset on the Sync system and rebuild profiles, PaaK and just about everything else. I did that the first time I came across this when nothing else worked.
This has happened me me twice now.
I sure do hope Ford comes out for a fix for this soon. It is truly a pain in the ass.
Oh well, we are on the bleeding edge.
