RWG
- Randal
- Jan 16, 2022
- Chaska Minnesota
- 2021 Mach E
- Retired
It's good to know there is a fix, albeit just software. Does anyone know what the root cause of the issue was/is? i.e. how did software cause a heavy duty, DC voltage, hermetically sealed contactor to overheat?
I have concerns.
The end symptom, result of this problem is an overheated contactor but what I want to know is Why, How? My experience with over heated contractors in other applications are, many times their was collateral damage to the contactor, related to the times it was overheating. As a result, in some situations I have experienced, a compromised contactor would eventually fail prematurely as collateral/cumulative overheating episodes kept on occurring. So if we are lead to believe the fix is software, then it means there was a software problem that lead to overheating that took out some contactors over time. On one hand, software fix to correct a software problem seems perfectly logical and I can accept that but on the other hand are my contactors now compromised after 5,000 miles of operation? And therefore maybe going to fail prematurely sometime in the future, most likely after the warranty runs out?
Furthermore, if these contactors got hot enough to sometimes weld together, that means sometimes there maybe collateral damage to the wire connections and wires attached to the contactor. Theoretically, an overheated contactor can do lots of collateral damage to other components.
A software fix may cure the problem from happening again on a new contactor and new production. What about a contactor that has been in use for nearly 6 months? Software cannot undo mechanical contactor overheating collateral damage that has already occured. How can I tell if a contactor has been compromised? Especially since it is hermetically sealed and probably cannot be taken apart or inspected.
If there is any logic to my concerns, than I would expect Ford to extend the warranty on any future failure related to that part, beyond the traditional 36,000 miles or 3 years. Also, if compromised contactors are a contingent liability, perhaps they should just be replaced.
Opinion from a former corporate warranty manager: Why wouldn't Ford choose to do software AND to replace parts? Perhaps because a software warranty upgrade on 50,000 vehicles is relatively cheap, but replacing 100,000 contactors and software is not, ( I believe there are 2 contactors in every vehicle) especially since the problem appears to be Fords software and not the component. Therefore there is no warranty cost recovery opportunity for the failed part. As such, Ford would be left bearing the total cost of this warranty/recall campaign with no assistance from the contactor supplier.
Curious . . . .
I have concerns.
Curious . . . .
