Billyk24
- William
- Nov 29, 2019
- PA
- Ford C-Max Energi, Premium Mach-E ordered
Did you actually monitor the HVB temperature via a third party hardware to know what temperature the HVB was? I have a scanguage II in mine for this and other purposes.,Note that the battery is located in the very bottom of the chassis and heat rises. (Although if you do park on top of hot asphalt that can raise the battery temp.)
Also note that the battery is a large thermal mass in that it will heat up pretty slowly when simply parked (its different when charging/driving since the heat in that case is generated internally to the battery).
The Focus Electric, with its batteries under the seat and in the rear cabin didn't really have to engage the cooling system that often for me, if at all during hot days (yes I'm in Michigan which is different from LA, Phoenix, etc. where it is frequently hot but we do, occasionally, get a 90+F day).
