Battery Life Question - Just received mine
Rugbyjay1
Jason
Ford Explorer, Mach E First Edition
Project Mgr
I was lucky enough to pick up my First Edition yesterday from the dealership and when I start to drive home with it, I noticed I was at 99% battery but only 170 miles to go. When I arrived home, I charged the car until complete and now it is at 177 miles at 100%.
Do I need some education on battery life for the car? I know it is estimated at 270 miles and this has me a little worried. Does the car need more experience on the road before I will see the real mileage after a full charge?
methorian
Roanoke, VA
IT Admin
The estimated range on the dash is what is most commonly referred to in the EV world as the "Guess-O-Meter", it's just that, a guess/estimate. The Mach-E takes a ton of info into account with giving it's estimate (prior driving history, temps, etc). Many have claimed the guess-o-meter in the Mach-E to be very conservative so far.
Your dealer may not have reset the EV driving history before you took delivery, so if you want, you should be able to reset the EV driving history in the Vehicle tab of the center screen somewhere (sorry, don't know exactly where off-hand). From there it will learn your specific driving styles and all and update to give it's new guess on range.
Rugbyjay1
Rugbyjay1
Jason
Project Mgr
Thanks so much for the information.
stmache
Scott
Syracuse, NY
2023 Ford Mustang Mach-e GTP, 2017 Ford Mustang EB
IT Manager, Photographer
I think we need a "What you should do after taking delivery of a Mach-E" sticky thread. This is excellent advice in re-setting the driving history.
dbsb3233
TimCO
Colorado, USA
That number should creep up in the coming days as you build a history on it. Probably won't get near 270 until summer, since cold temps are really hard on BEVs. Use of the cabin heater can take 10-30% off range. There are other losses to the cold as well.
I suspect you'll see that creep up to something in the 210-230 range within a few weeks. Then maybe 250-270 by mid-summer.
More appropriately, the car needs a bit more education of its own capabilities. How many miles does it show? It's probably basing the estimate on a very few miles and lots of idle time.
They could have fixed this with programming that nudged the initial estimate higher but they seem to be letting the car learn for itself.
DBC
Don
Volt ELR
This. More noticeable the more range the vehicle has, and can influence the range estimate for longer than you'd think.
timbop
A better projection is for you to take it for a 1/2hr to an hour drive, and look at the mi/kwh number the car shows you on that trip and multiply by 88. As mentioned the guess-o-meter starts out conservatively and adjusts based on your actual driving habits. It is also winter, so expect 25% better range in the warmer months.
