Beach Driving??
Jcastaldo1740
Jason
New York
Mustang Mach E
Hello,
Curious to see opinions or if it’s just facts, can you take the AWD model out on the beach?
Real soft and sandy by me, trucks get stuck a lot out there if not aired down enough.
Let me know!
GuliblGuy
Justin
North Tustin, CA
Shadow Black 2021 Premium 4X Mach E
It only has 5.7" ground clearance, wayyyyyyyyyyy less than a truck, and aired down gonna be even slightly lower. I think it would be very dumb to take it on a beach but..........to each their own?
Garbone
Gary
Loafer
Wife has had our 2wd on the beach. Stuck 3 times, once just at the booth. Torque+small patch+sand+weight= stuck.
Beach days are the only days she does not take the Mustang.
AlpaChino
JB
Indiana
Mach-e Premium eAWD Ext Range, Rapid Red
Bumping up this old thread just to see if anyone else has been brave enough to take their MME out on the sand. There's one beach in Michigan that I have my eyes on, but not sure I want to add a tow budget and public ridicule to my trip planning.
awp0
Aaron
boston, ma
MME Premium AWD ER
Wow, that is indeed brave. I'm nervous going over speed bumps with the MME's ground clearance (or lack thereof). Beach sand sounds terrifying.
Take shovels and traction pads. Make sure your tow points are labeled.
MacherAWD
North Shore MA
Software Implementation Manager
Select tires are very narrow, so even inflating down, thin tires, heavy car, low clearance....We promise not to laugh if you share stuck photos
AzCoronaDog
Jeff
Scottsdale, AZ
'12 Porsche 911 Cabriolet, '21 MME, '17 Yukon XL
With AWD and low enough pressure in the tires on fairly flat sand, it should do fine. I have spent countless hours driving on sand in lifted 4x4s, and it is the tire pressure that makes the most difference, but if you need some ground clearance there is no substitute. Still, I've seen plenty of dune buggies and VW bugs run in the sand without many problems.
I know the battery pack is supposed to be well protected and well sealed, but my bigger concern would be all that electrical stuff and salt water (assuming we're talking ocean beach).
AlpaChino
JB
Indiana
Jokes on you. I filled my tow points with Bondo for maximum aero. Spring break 2023 Michigan dunes here I come! 🤣
JSeis
AWD Select
No. Stupid idea. Our ocean sand has plenty of salt to digest metal. Plenty of places to beach drive here but I like my vehicles to last.
randomvoice
Mustang Mach E GT
All that weight with low ground clearance and torque kicking the sand quicker than traction pulling you out. Not a great combination. I'd stick to renting out an actual off-roader to beat around if I were you.
highland58
Seattle area
2021 Mach-E GT, 2023 Bolt EUV, 2018 F150 XLT
IT Solutions Architect
How many dune buggies does it take to weigh the same as an MME? 🤷‍♂️
I have considered doing this myself, but I think the ground clearance is a deal killer. Hard sand, no problem. But if you hit any soft sand and start to sink I think you will get suck.
Once the battery pack rests on the sand, all four wheels will spin and spin and spin, and the locals will laugh and laugh and laugh.
santa fe,nm
www.envirokarma.org
Solar Sales/install
Hello,
Let me know!
if you had super wide tires to float ya maybe....
but the front and rear diapers are going to pick up LOTS of sand sprayed in from the wheel wells.
I'd say.... not a great idea
santa fe,nm
www.envirokarma.org
Solar Sales/install
