- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
I seem to have a growing pile of mods and repairs as I go on down the road with my ePony 'EVKARMA', so I thought I would start a thread to act as an index to the various mods, workarounds, fixes, and enhancements to put together a rough index to various mods as an index to specific threads.
updates to come here in top post as I link to individual threads for mods
Some mods are 'personal', some are what I would HOPE @Ford Motor Company adopts as future design.... I hope all are helpful to future owners.
Late Feb - 2021 - I took delivery..... First one in Santa Fe, NM
March - 2021
March 2021
July 2021
November 2021
Feb 2022
April 2022
August 2022
October 2022
- future
add front tow hook
permanent mount 1500watt inverter
March - 2021
- removed front lic.plate bracket and plugged holes - cosmetic
- added charge port sticker, purely cosmetic
- added access holes to 12v connection points, and later added 3rd hole for access to HV disconnect... this mod *should* be included in future design for safety. https://www.macheforum.com/site/thr...n-points-hv-disconnect-relay-for-safety.4107/
March 2021
- temp fix for cargo cover flapping, usually I just take the damn thing out. https://www.macheforum.com/site/thr...-request-sir-better-cargo-cover-catches.5307/
- rear Hitch receiver install... should be an approved Factory option for functionality AND rear tow rescue. Pretty easy DIY install took about 1-1/2hrs. https://www.macheforum.com/site/threads/diy-install-torklift-hitch-for-bike-rack-etc.5714/
- purchased ODB2 BT reader to show desired runtime data susch as actual power (kw) output/regen with CarScanner phone App. I really wanted to see power in kW output/regen real-time... and found that the CarScanner phone App has customizable display for whatever data you want from ODB2. https://www.macheforum.com/site/thr...display-all-phone-apps-like-carscanner.20913/
- details on how to set up a custom dashboard on the CarScanner App to display data from a wireless ODB2 reader like Viecar are at https://www.macheforum.com/site/thr...rging-speed-and-regen.5479/page-2#post-160581
- dealt with center screen FAILURE due to heat. replaced under warranty, led to adding modified screen/phone organizer mod in August-2022.
April 2021- problems getting PAAK to work FINALLY resolved with un-install, re-install, and product updates
July 2021
- got (much lighter and cooler looking with very open spoke design) aftermarket wheels and lug nuts for 'all season' performance, and snowtires on factory wheels. https://www.macheforum.com/site/thr...y-lug-nuts-and-shaved-6-7-lbs-per-wheel.7491/
August 2021- swapped out drivers seat for much preferred Corbeau with better bolster and micro-suede. https://www.macheforum.com/site/threads/in-progress-replacing-front-seats-with-aftermarket.8021/
November 2021
- experimented a bit with 12v energy export for camping, work, and home backup.... up to 160amp (2000watt) continuous export is really quite easy, inexpensive and practical. https://www.macheforum.com/site/thr...120vac-power-from-lvb-connection-points.7317/
Feb 2022
- added Jack Lift Pads to prevent battery rail damage at tire shop, dealership, etc.... There are a couple ways to do it. I used modified Tesla pucks that press in. Some people have used aluminum pucks designed for Corvettes. https://www.macheforum.com/site/thr...lift-pads-to-protect-mme-battery-rails.14455/
April 2022
- Added third-party tri-fold cargo mattress and surprisingly inexpensive hatch tent for super quick and easy camping. Sets up in minutes! People at car show loved seeing accessories rather than just another new car. https://www.macheforum.com/site/thr...at-a-driveelectricweek-org-event-i-did.22228/
- did some 'significant' body work with touchupdirect.com paint with good results. https://www.macheforum.com/site/threads/diy-touch-up-for-bad-scratches-100-versus-1800.16977/
August 2022
- repaired broken rear cargo bracket.... really *should* be a design change and repair kit. https://www.macheforum.com/site/threads/diy-cargo-floor-bracket-repair.23845/
October 2022
- OEM tires replaced (at 18k miles!) with Continental ExtremeContact DWS 06 Plus 245/55ZR18 which is basically =+1 on width and keeping original diameter, and fits perfectly on my 8.5" Enkie TSV wheels .... a little added width is a really a great performance mod. not much clearance on calipers, but using 'short' weights for balancing works.
- original HVBJB finally puked... got remove/replace done in 10 days with cooperation from Dealership once the need for replacement was verified by Diagnostic codes thrown in 'SVS', and ordered via COPIS process . Finally driving 'without fear'. https://www.macheforum.com/site/thr...aler-must-use-copis-ticket-to-expedite.22360/
- future
add front tow hook
