Blue Cruise Not Available after latest 6.x.0 updates
summerlinLV
Las Vegas
22 Mach E Premium RWD; 22 BMW i4 40
I have a 22 Premium RWD ER. After the latest updates of 6.x.0 (thru 6.6.0), I found out that blue cruise is not available. I have the lane centering and hand free activated, but only get adaptive cruise control. I have tried it on multiple freeways that I know blue cruise is available since I used it previously before the recent updates. Have anyone encounter this problem? Not sure if it is software update related or should I take it in for service.
Gimme_my_MME
Dearborn
Check all your connected services and ensure they didn't get turned off
summerlinLV
summerlinLV
Las Vegas
Connected service and blue cruise showed active thru 2025.
Really? I have to share my life to use BC?
Strictly speaking, BlueCruise only requires the first and second one. The Share ones are also so FordPass can function correctly. Driving data is important so Intelligent Range works correctly since that is cloud based.
Yep, they are turned on, but no BC.
What's the BlueCruise map expiration date under General > about SYNC? Or does it just say map version?
Also make sure hands free is still enabled in settings, and verify you didn't accidentally press the steering wheel button that disables lane centering.
Triggerhappy007
TX
23 Premium VB & 22 Select GB
I've been having a similar problem for a month starting with 6.2 or 6.3. It works in 1/3-1/2 of the places it used to. It's working normally in my 23 with BC 1.2 on 6.1.
Mike G
N. AL, USA
'23 Mach-E GT-PE, '22 F-150 Lightning
If the OP is completely up-to-date there may no longer be an expiration date for BC hands-free since it's been replaced by a map version number now.
Ford Mustang Mach-E Blue Cruise Not Available after latest 6.x.0 updates Lightning_980
summerlinLV
summerlinLV
Las Vegas
The lane centering button is enabled. This morning, I tried to cycle the lane centering button and it showed driver monitored camera fault. Sounds like time to schedule a dealer visit.
drsss253
Sam
NJ
Mach E
I have similar issue after fordpass 6.6.0 update last night. No cruise control adaptive/normal/blue cruise is working. Any solution?
Wait a day and see if the gremlin gets bored and relinquishes control of BC.
