BlueCruise almost here... are you in or out?
Stormtrooper
Knoxville, TN
2021 Mustang Mach-E AWD Ext
PAAK and BlueCruise are on two different platforms with two different development groups.
Correct. Dresie (at left) heads up PAAK. Casie (at right) heads up BlueCruise.
Before anyone gets worked up, I'm just kidding and couldn't resist the setup.
I'm very happy with my car.
That’s it! BA or AF? I was on AF. Much better food than BA and the flight was 15 minutes longer ??? (more time in a plane = fun as long as it’s not 31E on a 4 hour flight on a 737 ?)
I can't read the aircraft registration number so ... no clue.
I suspect AF. If you look at the podium, you’ll see what appears to be a red lockout on the bottom front pilot’s side. There’s a white card above this with text. I can’t make out all the text, but it’s in French. To the best of my knowledge, it’s very rare to find cockpit controls on civil aircraft labeled in any language other than English?
SigSauer
Mark David
Columbus, Ohio
2022 Preiumn in DMG, AWD, ER and 1928 Model A Ford
Retired Sales Representative
Your comment makes no sense. PAAK and BlueCruise are on two different platforms with two different development groups.
Thank you and I appreciate your explanation. Lot of my comments make no sense, still grumpy. because our car is not here.
SigSauer
Mark David
Columbus, Ohio
You made me laugh, thanks.
There's probably a micro in that that home style VHF scanner behind the engineer's seat.
That’s not original equipment, so it doesn’t count ? besides, I doubt it’s even used for flight ?
Edit: I stand corrected - our friend @Kamuelaflyer can chime in but the left display is 121.7 which seems to match up with a common aircraft frequency ?
Ground control frequency at whatever airport they’re at.
MarleysMME
Scott
Amarillo, TX
Mach-E
Getting back to the thread topic, I'm in. Has anyone received it OTA yet? What indications of the of the update did you see?
Plutoman15
Chambersburg, PA
Excursion, Expedition
So what is the deal? Ford said summer, then third quarter…
I will say it again, @Ford Motor Company is starting to make Elon look fairly accurate. I know, low blow but start missing arrival times on things and you start to look alike.
When are we going to see the ota updates with blue cruise?
