Administrator
Administrator
Staff member
Mach-E
We bring exciting news! The 2021 Mach-E specs on Ford's dealer training site (obtained from our dealer source) are now showing an increase in horsepower, torque and kW output specs for all Mach-E trims and models!
Compared to the previously published specs by Ford, here are the new HP, LB-FT and kW figures.
RWD Standard Range Mach-E:
266 hp / 317 lb-ft / 198 kW​
(+11 hp, +11 lb-ft, +8 kW from original specs)​
RWD Extended Range Mach-E:
290 hp / 317 lb-ft / 216 kW​
(+8 hp, +11 lb-ft, +6 kW from original specs)​
AWD Standard Range Mach-E:
266 hp / 428 lb-ft / 198 kW​
AWD Extended Range Mach-E:
346 hp / 428 lb-ft / 258 kW​
(+14 hp, +11 lb-ft, +10 kW from original specs)​
Ford Mustang Mach-E Breaking: 2021 Mach-E Specs Increased Across The Board (HP, LB-FT, KW)! 2021 Mach-E Updated Specs KW LB-FT HP - Macheforum.com
pbojanoski
Peter
Pennsylvania
Jaguar I-Pace
Battery capacity specs?
The 75kWH and 99 kWH specs?
I believe you meant the kW equivalent of the horsepower number.
Dmcerm
Pennsylvania
2017 Ford Expedition EL, 2012 Mustang GT, 2003 Mercury Grand Marquis, 13 year owner/operator 1983 DeLorean DMC-12 - sold Nov. 2014
Teacher
Jee whiz. Increases already!
They're already finding efficiencies!
We bring exciting news! The 2021 Mach-E specs on Ford's dealer training site (obtained from our dealer source) are now showing an increase in horsepower, torque and battery output specs for all Mach-E trims and models!
Hot damn! 4% higher hp and almost 3% more torque.
Any improvement in the estimated range and efficiency?
Thanks for sneaking the news out!
Whatstreet
Fremont, CA
Chevrolet Volt, Ford Expedition
Electronics Engineer
I think this is more of an improvement in the accuracy of available information than actual changes that improve performance.
Sure. The Tech Specs from November were targets. The important news is the first pre-production demo/test units off the assembly line are exceeding the targets.
Dean Mach-E
Indiana
2017 Explorer Sport, 2016 Mini Cooper S
Do you think that will translate into longer range?
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
My RWD ER is UP which is great news. Just hope that they don't put the price back up
timbop
The published ranges were the 'at least' targets. I wouldn't be surprised to see the EPA range estimates come in higher before launch.
like, say, 10% higher as a guess?
