Broken Ford EVSE first time use
1969Camaro
Scottsdale AZ
2021 Mach E Premium, 2018 Prius Prime, 1969 Camaro
Trip to San Diego besides getting red ring of heat in El Centro and now after a week at Mossy Ford the brand new never used EVSE doesnt work. New as in original case still wrapped in plastic. Red Ring issue hopefully fixed with confirmation of module updates. Not sure what was working ok no longer functions as a result of the update.
I decided to try the Ford EVSE (I brought a spare from wife's plug-in prius) Toyota EVSE works perfectly. Ford has yellow fault. Plug/un-plug several times no luck. Mossy said Huh, need to ask Ford what to do. Seems pretty easy, get another one.
How much confidence do I have in this vehicle? Very little. Scared about driving home to AZ next week.
1969Camaro
Scottsdale AZ
Did you try re-seating the plug pigtail into the brick to make sure it was completely flush? It takes more force than you would think.
Several times.
Unplug charger from outlet.
Disconnect pigtail from charger.
Reconnect pigtail, ensuring it clicks. Push hard.
Try again.
1969Camaro
Scottsdale AZ
Try again.
Several times. Without plugging into vehicle blue LED lights, then red and ultimately yellow, Can not be overheat as its 67 degrees here.
KevinS
A bad charger is a bad charger.
I guess the question would be, does the charger work with the Prius?
If not, take it back and get a replacement.
1969Camaro
Scottsdale AZ
I would except the Prius is 374 miles away in AZ.
  • Wow
Reactions: ARK
Benjamin Kegele
Benjamin
Northern California
MME 21, VW Atlas, Harley Davidson Heritage Softail
I know you said you tried already. I just post this so you visually see how flush it has to be.
I reached out to ford here on the forum once because of my charger. They gave me a phone call and said there a known issue with the charger and there is several which fail. So this is the second possibility
KevinS
That's too bad. I suppose you could emulate a bad late-night talk show bit and walk around accosting EV owners asking if you can charge their car. :)
I have never even tried my Mobile Charger. Sorry to hear you are having an issue. 🙁🐩
