California Route 1 Wheel part #
OttawaGuy
Gatineau, Canada
Mach E RWD SR, F150 XLT Special Edition
Busy!
Anyone has found the parts number for the 18" aero wheels on the California Route 1 model?
I'll need winter wheels for my Premium and would like to get as much, no wait... as little range impact possible, so was thinking at looking for CR1 wheels (if they aren't too expensive of course) instead of other winter wheel options
JCHLi
covers might be 1130, 18 inch rims might be 1007 (A or B, not sure if they are route 1 or selects...)
Boselka
Jason & Travis
Denton, TX
vibedigital.marketing
'16 CMaxEnergi|'17 FocusElectric|'21 Mustang MachE
Website Design, Development, and Digital Marketing
Did you ever end up figuring this out or doing this? I have been considering the same.
OttawaGuy
OttawaGuy
Gatineau, Canada
Busy!
No finally went with plain steel wheels bought on Costco for 99$ each ... Figured the OEM wheels would be way out of price for me!!
tuminatr
Saint Paul,MN
2021 MME, 1964 G1 Mustang, 1993 Mustang
Sales
Got it that this is an old thread but the part numbers are
Wheel LJ8Z1007D at Tasca $829 each
Wheel cover LJ8Z1130B at Tasca $113 each
Center cap $11 each
I had the same thought about range impact but that's too expensive for me.
OttawaGuy
OttawaGuy
Gatineau, Canada
Busy!
Center cap $11 each
I finally went with plain old steel rims for winter in 18".
I'll be honest with you, when the weather was warmer I didn't see an impact on range and consumption with the winter wheels and tires.
Some seem to make a big fuss out of it, but here I saw zero impacts on our day to day driving.
Cold weather has an impact afterwards..
tuminatr
Saint Paul,MN
Sales
I think if you bought a low rolling resistance winter and went 18" it probably has very little effect on range.
McS
Peter
Sweden
Ford Mustang Mach-E
Center cap $11 each
I am looking to replace my center caps.
Would you mind sharing where you got hold of yours?
SnatrapS99
Ryan
Redondo Beach, CA
CA Rt1 RWD DMG named "Tango"
I work for SpongeBob.
My CR Rt1 gets here early next month. I am thinking about changing the wheels. I would like a wider (maybe bigger) wheel. Is that even possible to do on the CR Rt1? If so, I may be selling my OEM wheels.
Khalil
Philadelphia
2021 Ford Mustang Mach E California Route 1
I have a California RT1 and swapped out my wheels for a GT set, so I at least know 20s will fit. I’m pretty sure you wouldn’t have a problem going wider.
If anyone is looking for a set of California RT1 wheels + tires I’m selling my set.
SnatrapS99
Ryan
Redondo Beach, CA
What loss of range did you see? Also did you have to recalibrate the speedo or anything due to the increase in wheel size??? Thanks.
Khalil
Philadelphia
I’ve only had them on for about a week and a half now, but I haven’t noticed any drop in range. My miles/kWh have been in the same range as stock. The weather around me has been milder lately so that may factor into not seeing a change in range.
I didn’t need to recalibrate the speedo. Based on my trips using waze and google maps the speedo is fine.
tuminatr
Saint Paul,MN
Sales
You would only make the speedo inaccurate if you went with a tire that has a different overall diameter than stock.
For example
225/60/18
245/55/18
225/55/19
245/50/19
245/45/20
275/40/20
Will all work and the speedo will be accurate, some sizes may need a wider than the stock rim.
tuminatr
Saint Paul,MN
Sales
This is the center cap I used. Part number FR3C 1A096 AC
