Cancelled! Intelligent Cruise Control That Is!
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
I’m going to go way out on a limb and make a guess here. I think you may have murdered an insect, and splattered it over the front camera.
mpshizzle
Utah
Mustang Mach E 4X
Ha ha ha that's definitely a possibility, but I'm thinking maybe not? The regular lane keeping was still just fine, and that uses the same camera. I'm thinking it's a software bug that needs to be murdered not a.... Hardware bug?
That was a stretch ???
OH2AZ2OH
Dublin, OH
Mach E 4X
Bug splatters definitely fall into the Wetware bug category. You don't read enough sci fi.
SPatil
Stephanie
Mich
Ford Mustand Mach EV 2020
I can’t speak to speed sign recognition - the speed sign indicator continued to be displayed in the IP. The car just reverted to regular adaptive cruise control with lane keeping. The indicators were the vertical green lane keeping indicators and the blue distance indicator at the front of the car.
SPatil
Stephanie
Mich
Since last Friday August 20, I am getting the message that INTELLIGENT CRUISE CONTROL SPEED SIGN RECOGNITION IS NOT AVAILABLE. Cruise control no longer recognizes the change in speed limits. I can still set speed control, but have to manually adjust speed limit. Anyone else? Suggestions?
mpshizzle
Utah
Mustang Mach E 4X
Does your lane keeping work? I'm wondering if your camera has failed
Last night, I was driving on a 4 lane divided limited access highway, doing 65 MPH with intelligent cruise control on. The Blue Bubble of happiness was surrounding my car, and the car was gently steering along with my hands at 9 and 3, gently applying torque, as necessary to make sure it was centered where I wanted it in the lane. This was a well-striped road, and the weather was clear. Little to no other traffic. All of a sudden, the bubble turns bright orange, and the hands on steering wheel icon turns to the text “Cancelled”. The system then reverts to regular adaptive cruise control with lane keeping. I was unable to get intelligent cruise control to re-engage. When I returned home later that night, intelligent cruise control worked without any problems.
has anyone else seen this? Any idea what may have happened?
There are a few roads here that seem to cause that to happen. I've gotten used to having it turn off occasionally. The only time I've had problems engaging it though is when I throw to my switches and push too many buttons at once.
SPatil
Stephanie
Mich
Yes. Lane keeps working. According to manual, pg 249, Speed control can be governed by some sensor behind some 'interior' mirror, OR by the navigation program being used. Do you know if the sensor is behind the rear view mirror? I get the error message whether I am using Google Maps through my Pixel 3 XL. I am not sure if I get it when I am using Ford navigation system. I'll have to try without my phone in the car. Speed Control recognition used to be a real asset. Something happened.
Creaky
Bas
Netherlands
MME RWD SR
Anything with a plug on it...
I've had this situation once. I passed someone and then tried to return to the previous lane to quickly for the lane centering's taste, it beeped at me that it thought I was cutting someone off but I ignored it, because there was plenty of room. After that lane centering switched off and didn't want to turn on again whatever I tried.
I guess it was pissed off at me... ?
Next time I started the car again it was back and worked fine.
mpshizzle
Utah
Mustang Mach E 4X
I don't know for sure, this is an assumption on my part, but I think it must. That's the only camera with a high enough field of view to see the signs. I'm pretty sure the other cameras are pointed at the ground.
In any case a sudden failure like that often points to a hardware issue. Perhaps try a master reset just in case it's softener, but If I were you I'd take it to the dealer and take advantage of the warranty.
Joelalt
Joel
2021 Mustang Mach-E
I've experienced this same issue a few times. After a stop it worked fine when I got back in the car.
SPatil
Stephanie
Mich
I've checked every day and it has not restarted.
I did have to do a sync reset recently. That did not help.
I appreciate your input.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
Machine Control Specialist
Is the windshield clean in the area of the camera?
