Car fault or EA fault?
me0wster
Timothy
Mach E GT
Hi. A new user to the forum here.
Just came back from trying to charge at 2 different EA locations. Tried to charge on 4 different stalls (2 on each location) on all the cables on the units. I've tried starting the charging via the EA app and via a credit card. The car says that its the charges fault. Called up EA on the number and they've restarted (and even stared the charging from their end) all 4 stalls and in the end, the person on the other end says its the car issue.
Side note:
  • Came back home and plugged in and the Level 2 charging works
  • Just received 3.6.2 last night
  • This is probably my 3rd or 4th CCS charge
What is the next step here?
Edit:
  • `via the EA app` instead of `via the app`
ThatGuyLando
Iowa
22 CR1
Software Developer
Plug and charge enabled? I've had a lot of issues with that to the point I just turned it off. You can still use your free credits by activating the station before plugging in, in the ford pass app hit the find chargers, and follow directions there once you find your station.
kltye
IB MME Premium RWD
Side note:
Edit:
What was the error message on the station?
me0wster
Timothy
Mach E GT
Nothing much really. It just spins and says reconnecting and brings me back to the main screen. In the car, it says "Charge station fault" just like the image here (https://bit.ly/3j5Nz8E).
flapjake314
NYC
Mach-E Select AWD
i see this all the time it's always been EA's fault. you say you started via app but do you have plug and charge disabled?
me0wster
Timothy
Mach E GT
If you mean the Plug & Charge feature from the Ford App, no. I don't have that Blue Oval even setup.
kltye
IB MME Premium RWD
Yeah, that sounds like a charge station problem rather than a car one. Anyone else on Plugshare report issues with those chargers recently?
me0wster
Timothy
Mach E GT
There were issues on the charges 2 months back then green checkins on Plugshare.
When I moved from one station to the next, a Taycan pulled up to the unit I left and was charging. The driver was not showing any sign of frustration.. :|
kltye
IB MME Premium RWD
Hmmm. I've seen compatibility issues on EVgo chargers, but never on EA. Are you able to try another DCFC provider? Hard to tell what the issue is otherwise.
Space Ghost GT
Delaware Ohio
GLE 450, space white GT received 11/04/22
Nerd
Enable charge and go and get always start that charge from the charger. Never had the car successfully start a charge.
me0wster
Timothy
Mach E GT
Yeah. That's what I'll probably do. Both the EA's I tested were 10-15 mins away. The EVgo is 30 mins away. The EAs are on the way to the EVgo.
I guess I can sign up for the Blue Oval and try.
Open EA app.
Activate charger.
Plug in.
ThatGuyLando
Iowa
22 CR1
Software Developer
Just update the post to clarify that I tried to start the charging using the EA app.
If you still have credits (assuming here) you have to go through fordpass app or p&c to use them. Using the EA app will result in you paying.
Now if you are intending on paying then that sounds like an EA issue, or maybe you still have p&c enabled while trying to use the EA app? Not sure if that may cause conflicts.
SpaceEVDriver
Ground-based: CA Route 1 AWD, ER
Planetary Science
Once we depleted our Ford credits for EA charging, we disabled plug-and-charge on the car.
Our procedure is:
Pull in to stall, turn off car--in my experience, EA will not talk to the car if it's on.
Open EA App on phone, make sure it's logged in, and find the charger on the map.
Hop out, plug in charging cable.
Go through EA's screen on the charger, selecting the "Membership" option (or whatever it's called).
Once the charger screen indicates it's ready to charge, activate the proper charging station on the EA App.
