CarPlay issue
Superdeg
Knoxville, Tennessee
2021 Ford Mustang Mach E
I have a recent issue where Apple CarPlay disconnects the Bluetooth under Connectivity and then PAAK will not work. I can have either CarPlay or PAAK but seemingly not both. Anybody having a similar issue?
Neil4Real
CarPlay does disconnect Bluetooth connecting to the car via Bluetooth, but the Bluetooth connection for PAAK seems to still work. I actually can't think of when CarPlay would be on and I'd need to use PAAK. I've done accessory mode before, which turned on CarPlay and I could still start my car after using PAAK while CarPlay was on.
JohnnyForensic
VA, US
Digital Forensics
Yeah, they are actually two separate Bluetooth connections. CarPlay and Bluetooth to the SYNC unit canā€™t exist simultaneously, but the one that controls PAAK is still online.
Go into your iPhoneā€™s BT settings and make sure you still have the two devices listed. If you deleted one because it didnā€™t look right, that would have done it. One will be like ā€œMustang Mach-Eā€ (pretty sure thatā€™s the SYNC), and the other would be ā€œ<LAST 5 DIGITS OF VIN> MACH Eā€ which should be the PAAK.
Superdeg
Superdeg
I thought you were onto something but I do have 2 separate Mach E Bluetooth listings although they are not always Connected. The dealer thinks it is because I have an iPhone8. But both have worked in the past. I have Reset several times.
JohnnyForensic
VA, US
Digital Forensics
Hmm. If youā€™ve reset PAAK, did you forget the Bluetooth connection in your iPhone for the Mach-E? I had trouble with that after resetting PAAK until I dropped the old BT connection and let it establish a new one.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Mach-E
Hello! Send us a private message with your MachEā€™s VIN and current mileage. Allow me to see what I can do to assist with this software issue you're experiencing.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Are you starting the car with PAAK, and then once CarPlay connects you get the no key detected message?
If so, That is the same behavior I've always had with AndroidAuto. Once AA connects, the phone doesn't hold a reliable BT connection for PAAK. It connects, and disconnects pretty regularly. The car continues to function normally once its started.
Superdeg
Superdeg
Yes, I definitely experience that exact behavior.
benk016
Ben
Tulsa, Oklahoma
