Charge Port Door Locked?
cjljr41
Chuck
Windsor, CT
'21 Mach-e Premium 4X, '23 Escape Platinum Hybrid
Does anyone know if the charge port door opens with a release lever inside the car, or do you just walk up to it and press to open? Slightly worried about vandalism.
Wonky_Donkey
Tony R
Norwich UK
2022 Mach-E RWD ER
On the pre prod models I've seen it has a locking bolt on the flap that only allows it to open when the car is unlocked and it's activated by a button.
The latch can be seen in the image below. The latch is on the far left of the image (just a nub showing), and the receiving latch mech is on the middle far right of the image.
It should be quite secure when not in use.
Ford Mustang Mach-E Charge Port Door Locked? Mach-E Charge Port
c max
phil
northern new jersey
'23 Premium Rapid Red
I have been driving my c-max energi since 2013......charge port door is a dimple you push, and it swings open, push same dimple to close.......have never had a problem with vandalism and now that I've opened my mouth hope that continues, haha
