Charge to 100% not available via FordPass App?
ReelSweet
Jody
Connecticut
Mustang Mach E
I set the charging max to 90% on the FordPass app and on occasion use a function on the FordPass app to charge to 100% when going on a long trip. At the moment the FordPass App functionality for the "charge to 100%" is not available (some global issue). Can I charge to 100% via the screen in the MME?
Leigh Byrnes
Leigh
2021 Mach E
I was hoping to but I didn't see a way.
I thought you could set the charge level in the schedule in the car - should be able to change it to 100%?
If not, deleting your location should default to 100%.
djjerv91
Jonathon
2021 Mustang Mach-E Premium RWD ER Infinite Blue
Should be a setting in the app to always charge when plugged in. If that is turned on, the car will charge regardless of time of day, just has to be plugged in.
I think his issue was due to this morning’s FordPass outage, nothing could be accessed in the app.
Ride_the_lightning
Midwest
Mach E Premium SR AWD
I had to change my schedule and maximum in the car, and that worked. Unfortunately there is no one-click way to do it from the car though.
ReelSweet
ReelSweet
Jody
Connecticut
Mustang Mach E
thanks for the idea on adjusting location....there is a slide/switch on the Charging screen under settings for Charging Location that I adjusted and now charging to 100%. I have a 150+ mile road trip this afternoon and like the security of going up in battery % in case I run into long periods of traffic and also don't want to skimp on the e-heat with my 85year old parents on the MME.
