- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Still not right. The Ford Mobile Charger is a 32A EVSE and delivers 32A. The amperage number of an EVSE is always what it actually delivers. The SplitVolt charger is 40A and delivers 40A. The Clipper Creek there is a 32A EVSE (says so in the title), not a 40A. You might be confused with the model number because Clipper Creek has chosen to number their models based on the circuit amperage they require.Digging a little bit...yes I was wrong...but not about the Ford provided EVSE. Ford provides a 40 amp EVSE that will deliver 80% of that current, 32 amps, to the car.....
https://www.ford.com/support/how-to...lic-charging/what-is-the-ford-mobile-charger/
The linked SplitVolt 40 amp charger does not follow EVSE naming convention. It delivers 40 amps to the car...but requires a 50 amp circuit to do so. Other manufactures would call it a 50 amp EVSE. My mistake was to assume SplitVolt followed convention when naming its units.
https://www.amazon.com/dp/B08JXR7HGN/ref=emc_b_5_i?th=1
See for an example of conventional EVSE naming nomenclature this 40 amp Clipper Creek that will also deliver 32 amps to the car.
https://store.clippercreek.com/leve...-EVSE-Charging-Station-25-ft-cable-NEMA-14-50
The 80% rule only applies to the CIRCUIT, not the EVSE. So a 32A EVSE is to be used on a 40A+ circuit, but again it's incorrect to call it a 40A EVSE because it doesn't deliver 40A.
