Cleaning interior trim
Old_Norm
Columbus Ohio
Looking for suggestions for a good cleaner for hard interior trim (door panels, door sills, etc.) Trying to avoid an Armorall shine.
TIA
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
Old_Norm
Old_Norm
Columbus Ohio
Old_Norm
Old_Norm
Columbus Ohio
ReverendPete
Pete
Denver, CO
Software Developer
Off topic, but where did you get your lighted pony?
Straight from EV-Vida (which, if I understand correctly, is just AOSK's online storefront). Looks like they're currently out of stock. https://ev-vida.store/products/mustang-mach-e-rear-pony-emblem-brake-led
FWIW, I love the look of it, but the black plastic middle sticker part that is "removable" is kind of removing itself, and I've had to give it a little extra adhesive. But the install was fairly straightforward just following their install video on YouTube...
Old_Norm
Old_Norm
Columbus Ohio
I've got the one that was being peddled here. But from all the negative feedback, I'm reluctant to install it. Probably go with the EV-Vida one as well.
Mauser
Canada
'22 Mach-e GT-PE Space White
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
I just wipe down interior panels and seats with a wet chamois after washing the car.
Its_my_wifes_car
New Hampshire
2023 - Premium AWD ER
I STARTED using Armorall on ours once and it doesn't work well at all on the "flat-textured" interior. It just leaves blotches because it appears to absorb much more than a traditional car interior - I saw blotchy marks that had a lot of the liquid and other areas that had none. So I immediately stopped. Now we just use a very damp cloth to wipe down any dusty surfaces and that does the trick. No need to over-complicate it is our feeling.....
Griot’s Interior detailed for most cleaning and protection. If it needs more than that then I’ll use water with a bit of soap in it and a soft brush or microfiber towel.
cryptk
Texas
2023 Mach-E GTPE, Blazer EV RS (reserved)
I'll second 303 aerospace protectant for maintenance dusting. If you need something a little stronger to take care of a problem area, give Green Star from Koch Chemie a try. For the soft surfaces, Pol Star from Koch Chemie is nice as well.
