cleaning pano roof
c max
phil
northern new jersey
'23 Premium Rapid Red
Good morning......my '21 Select did not have the pano roof.....my '23 Premium is the first car I've ever had with a pano roof......those of you with much more experience than me must have a secret way of cleaning the roof......do you wax, use a regular window cleaner, or something else??......would prefer a simple solution to the cleaning situation......right now I wash the roof when I wash the car, rinse, then dry.....
Mach1E
I have a 2021.
I have never done anything extra to clean the roof.
It’s kinda like washing your legs in the shower; who has time for that and what’s the point? 😜
KevinS
I don't have a glass roof, but if I did I would probably use something like Rain-X on it just for that swanky water beading. I have used it on my windshield and appreciate the effect it has.
c max
phil
northern new jersey
Yes exterior......I will continue with the same procedure, washing it as though it was a non pano roof, haha.......as I said, never having had that type of roof, I didn't know if there was special treatment......sometimes the answer is the simple one, haha.....thanks for the responses....
GreaseMonkey
Chicago, IL
24 Mach-E GT
I use this product (pic below). After I’m done washing, I dry with a blade to get 80% of the water off, then spray this product and dry with a microfiber towel. It does need another pass with a clean towel after a few minutes. I also use it on side windows but use Rain-X on windshield and lift gate as I find that Hydro View doesn’t do well with wiping.
Ford Mustang Mach-E cleaning pano roof IMG_2400
hprose
Harvey
Pinellas Park FL
F250 and a Mach-e on order
Financial Advisor
I use Meguiars spray on ceramic hybrid on the whole car including the glass. It has worked very well. The first coast is spray around 3 times on a panel while wet and work it with a microfiber cloth then buff with a clean cloth. Second time, 6 month later, spray on a wet surface, spread it with water spray, dry and buff.
hartmms
Phoenix, AZ
Mach-e GT-PE, Ram 2500
engineer
I used Adam's Graphene Ceramic Coating on both the roof glass and car body.
Moxiemoney
Brent
Portland, OR
'23 Premium AWD ER
You can probably pick any of the products the other posters listed. I use something similar, and like them, Just use it on the entire exterior including glass. It does a great job on the glass, much better than the glass-specific cleaners I have. Wipe on and wipe off, with only a very light buff. I don't want to spend a lot of time cleaning my car, but do like it clean.
Ford Mustang Mach-E cleaning pano roof 1000004728
Wash as normal. I do put a coat of wax on it when I wax the car.
intensifi
Jeff
San Mateo
GT
Wash it. Clay bar (or mitt) with lubricant. Rinse. Dry. Surface prep (alcohol spray). Graphene coating. Keep dry for a couple of days.
Say WOW! the next time you wash or it rains.
BTW: repeat process for all painted surface and glass.
Mach1E
joke redacted
Mach1E
Humor is subjective I guess. 🤷‍♂️
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
I have a 2021.
Reminded me of this:
Ford Mustang Mach-E cleaning pano roof IMG_0766
