Concerned what I found when installing hitch
RedDragon
All - installed the draw-tite hitch on my vehicle today. While under the car I noticed two things that are concerning me - please let me know if the concern is warranted or not. By way of background I have a 22 premium extended range. It was picked up from dealer in mid October 22. As if today, my car only has about 1370 miles on it. It is always parked in a garage. Iive in New Jersey, and there hasn't even been much of a winter yet.
Concern number 1:
The picture below is of the arm that extends from the rear electric motor to the wheel. There is an orange substance on the cylinder that is closest to the motor and a lot of this substance at the part where the arm meets the wheel. It look like rust to me but I'm no expert. What do you guys think? If it is, is it normal to have this much in those areas for a car that is this new ?
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231016122
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231405928
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231408119
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231351662
Concern number 2:
On the back of the battery casing, unnoticed this brown substance? Is this normal? Is that some sort of sealant?
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231142138
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231155069
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_231213098
Ford Mustang Mach-E Concerned what I found when installing hitch PXL_20230107_230953495
Ha, yes that’s rust and it’s perfectly normal. Those axles rust almost instantly, it was probably like that before it left the factory. One rain and it will look like that.
The brown stuff on the battery is the sealant they used on the seam when assembling the bottom of the battery case. Also perfectly normal.
awp0
Aaron
boston, ma
MME Premium AWD ER
I noticed your first concern when I installed my hitch. Actually what seemed more bothersome was that it seemed like I was missing a seal/cover (like on the right side of your second photo where the shaft looks weirdly exposed). I remember googling around for photos of the rear drivetrain just to make sure that was normal!
RedDragon
RedDragon
Thanks all - you have successfully quelled my innate paranoia!
newmme
Volt
It is probably ok. Ford did have some large recalls for this in the past.
Ford Mustang Mach-E Concerned what I found when installing hitch Screenshot_20230108-140110
