Creep mode on Mach-E
Ranger Rob
Rob
Utah
BRZ, 4Runner
Ranger
I haven't seen this discussed here but has anyone read or know how the Mach-E will behave when stopped in Drive mode and you lift off the brakes -- will it creep or will it sit neutral? Will it have a creep mode that you can enable / disable like in Teslas?
I'd personally prefer having the car creep. Because even if it didn't creep automatically, I'd still have my foot on the brakes anyway at lights to guard against some inattentive driver hitting me and pushing me into an intersection. Also like having creep to prevent car from rolling backwards on decline.
What do you guys prefer?
hybrid2bev
The vehicle will come with a function called auto hold. The car will stay in place if you take your foot off of the brake pedal if the car is stopped for 3 seconds or more. Even with one pedal driving. Don’t know if the auto hold can be disabled. I would prefer the car stays in place.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Since the car will have a setting allowing you to turn on/off one pedal driving my guess would be when one pedal is off it will creep, when one pedal is on it won't creep.
BadaBing
Tony
Bellevue
Mustang & Explorer
Makes sense. I think this is how it'll work too. I like the engineer's approach of something for everyone -- one pedal driving or not, creep or not.
AceSpades
Nevada
2014 Mustang GT
I think I would prefer creep as well but have to see how it feels. My concern is ramps and roads that aren't perfectly level. If you stop the car at a light or stop sign and the road isn't perfectly level the car will start to roll forward/backward once your foot is off the brake. You'd have to hold your foot on the brake so the Creep Mode on/off is irrelevant?
hybrid2bev
Once the auto hold is engaged you can remove your foot from the brake pedal. The auto hold function will not let the vehicle roll forward or backwards.
cjljr41
Chuck
Windsor, CT
'21 Mach-e Premium 4X, '23 Escape Platinum Hybrid
For those of you that have your car, does it creep forward on a flat surface when you let your foot off of the brake?
J Duce
Jean
Jamaica, NY
2017 Explorer Sport
I
believe it can be canceled. I think i have the option and will check it later.
Yes, but you have to turn off Auto Hold and 1PD.
I have tried all the various settings. I prefer turning off Auto Hold and 1PD because I like the vehicle to creep when I lift off the brake.
MrRossKeys
San Jose, CA
Mustang Mach E First Edition
Same boat here. I like the creep so I turn off auto hold and 1pd.
Recently I went thru a fast food drive thru and realized that it would be great to take my foot off the brake and keep the car still. Looked around for a physical auto hold button like most cars have and didn’t see one. Ended up putting the car in park. I debated turning on auto hold for this reason but decided against it because at stop lights I like to creep forward.
louibluey
FE "Louibluey" GB
I drive almost all OPD, so no creep. I did find maneuvering around tight spots, like at the EA charge stations when I had to keep moving to try another, it was a lot easier to move around tight spaces with hold and OPD off.
cjljr41
Chuck
Windsor, CT
I think this is what I'll do for when the kids drive it. I can only imagine someone not verifying whether it's in D or R and backing (or driving) into something like the garage.
Yeah, this is another thing that's buried in menus, so it's not easy to turn it on and off on the fly. I use Auto Hold in my current car frequently, but turn it on and off when needed with a physical button. I really hope that Ford adds the ability to set custom shortcut buttons on the screen that are always there. Auto Hold and trunk open would be high on my list.
wmaney
Wade
Mach-e GTPE, daughter drives Ford Focus Titanium
I turned auto hold off. When I pull into the garage even using the camera, I frequently was not getting as close to the staircase barrier wall - I would then try to move forward but subtly pushes on the accelerator was a little difficult - creep solves that problem - modest uphill drive way but flat garage floor - so creep helps. Just my preference.
