- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- MME (delivered 2/26/21), DIY eMiata BEV
- Solar Sales/install
AGM batteries have a slightly lower charge/equalize voltage because they are sealed and you don't want the electrolyte in the 'glass mat' to boil and create gas/pressure inside the battery or dry out the mat. The dc-dc output voltage is probably controlled pretty tightly and factory set for the AGM installed in the car, and compensates for voltage drop in the LVB with low temperatures. Tight control of the charge voltage is needed to regulate the current going INTO the battery to prevent problems and extend life.AGM batteries are not happy if they are charged too quickly - above 13.8V, if I remember correctly. With ICE alternators, charge voltage is typically 14.4, but if you install an AGM, the voltage needs to be turned down to below 13.8V. The company I work for builds a vehicle with AGM battery because it often sits without being used for weeks at a time. However, a special 13.8V alternator is used. Anyone know what the DC-DC LV charging voltage is?
This is why my best guess is there are some issues with the dc-dc voltage regulation, charge controller, software, and/or sensors monitoring the LVB voltage and temp. which *might* be temporarily sidestepped by swaddling your LVB in a 12v electric blanket for the winter... at least until there is a more general fix
